Help! My mouse isn't working properly
Solved by Semper,
2 minutes ago, Dragjov said:I feared this but it's just that when i banged it i heard a windows notification sound and the screen flickered
Were you attempting to push your mouse through your desk?
I don't know that I can come up with a scenario that would warrant hitting your mouse hard enough to cause your screen to flicker that don't revolve around having some anger issues.
The windows notification you heard is more likely to indicate that it's a hardware issue, for a brief moment, windows likely failed to recognize that the mouse was still attached. With software failure, you're more likely to get some type of error notification popup than just a sound.
