so my board is a intel dh77eb okay and the issue i am having is when i put a wifi card in this slot on my board
it doesn't work i boot into windows and check device manager nothing for the wifi card
Btw this pic is taken from another off google not my board idk
but this is the port i tried using and nothing
wifi card isnt broken i have tried 4 different cards and still nothing checked bios for option to turn it on Nothing
 Image result for wifi card port
https://linustechtips.com/topic/1027242-wifi-does-not-work-help/
Are there any unidentified devices listed in Device Manager?
I would recommend you uninstall any rivers you have for wifi, reinstall, and see what springs from that.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
no theres not. it doesn't even list the device at all
i wonder if it has to be enabled in BIOS?
System specs:
On 1/29/2019 at 10:02 AM, JoshSigner said:
Nah their too slow
If you buy something cheap like a Edimax, but a alfa network awus036neh is literally nothing near slow, it works better than onboard cards.... don’t just make assumptions automatically and say it’s slow
its not a assumption when i have bought good brands it only gets 50 mbps sorry thats slow when Ethernet easily gets 300+ for me
Then you bought something cheap. You can easily get 255+ or even 850+ (GHz) mbps adapters, integrated cards aren’t as amazing as your making them sound, even gigabyte makes external adapters than can get even faster speeds than what I’ve stated.
Well there's a hell of a lot more to it than just pairing transceivers transfer rates. Interference, environmental EM saturation, and physical structures, directors, power, and distance all play a role in actual throughput.
System specs:
Internal cards aren’t always better than external adapters, and some externals can be better than most internal cards, I’m sticking to that.
Quite the Schrodinger's Cat-like reply.
System specs:
