Updating chipset on 5months old system
Solved by LogicalDrm,
6 hours ago, Allupyourfinger said:@srna Yes, updating the chipset drives wont do any harm.
You can use a program like IOBIT's driver Booster to install a lot easier.
Please don't recommend that crap. Its more likely to break something than fix anything. Besides, free version is pretty much useless and makes up drivers that don't need update as being vulnerabilities.
@srna, you can always update to newer driver as long as OS is supported. 5 months is rather short period. I've installed driver updates where versions are 2+ years apart. Driver installer always has all previous installs included as people only get the latest.
