Ryzen 5 2600 Temps
Go to solution Solved by balzer45,
Just did a quick google search and it brought up several other people with the same issue. Looking into it, it seems like its just a problem with iCUE and I would trust  Ryzen Master over iCUE any day. If you're looking for a program to notify you if your temps get too high, check out Core Temp.
P.S. I'm not familiar with the Ryzen Master software so that is why I suggested Core Temp
Hello. I recently upgraded my PC to a Ryzen 5 2600. When I open Ryzen Master it says I'm idling at 35C. But when I open iCUE (Corsair's RGB Software), it says I'm running 86C at idle. I'm not sure what the problem is. I have an AIO cooler (Thermaltake 240 Floe RGB). I made sure to apply new thermal paste and wipe the old compound off really well.
There was no overclocking done.
Thanks to any responses in advance.
IMG_3724.thumb.jpeg.806f57cf6c36e031bbcb54ef1ab8140c.jpegne. IMG_3725.thumb.jpeg.744d815e4535f1d58c002061ec4ce870.jpeg
CPU- AMD Ryzen 5 2600
Cooler- Thermaltake Floe 240mm AIO Cooler
Motherboard- Gigabyte AORUS X470 Ultra Gaming
RAM- (2x4) 8GB Corsair Vengence 2400MHz DDR4
Storage- SanDisk 250GB SATA SSD
GPU- Gigabyte RX580 8GB
PSU- EVGA 500W 80+
Case- CoolerMaster MasterBox Lite 5 RGB
https://linustechtips.com/topic/1026558-ryzen-5-2600-temps/
Edited by balzer45
My pc specs are as follows:
GTX 1080 GPU
intel i7 6700k CPU
16GB Ram
2TB HDD
500G SSD
Gigabyte Gaming 7 Motherboard
https://linustechtips.com/topic/1026558-ryzen-5-2600-temps/#findComment-12238136
Try a couple more hardware monitoring software applications like openhardwaremonitor and MSI Afterburner. One of them is clearly wrong.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/1026558-ryzen-5-2600-temps/#findComment-12238138
ryzen master overall is the most accurate when it comes to ryzen cpu temps
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1026558-ryzen-5-2600-temps/#findComment-12238200
I checked on MSI Afterburner and also Core Temp. Everything had the same temperature besides iCUE. I just happened to open iCUE today and I saw that high-temperature reading. Thanks to everyone that replied!
PSU- EVGA 500W 80+
https://linustechtips.com/topic/1026558-ryzen-5-2600-temps/#findComment-12238347
