Custom Gaming Rig running lagging at 30fps
Solved by k.m.p,
check msi afterburner, in the settings you can enable it to monitor tempureture and usage of cpu (including induvidual cores), gpu and memory, see which part is running at 100% or closest and that's likely the problem.
Its most likely your cpu is the culprit
Featured Topics
c0mplexx* ·
Posted in CPUs, Motherboards, and Memory2 -
Skelitor ·
Posted in General Discussion6 -
1
4
2
13
6
Sir Judgementz ·
Posted in General Discussion0
