“Upgrading sound for gaming”.
Solved by Turtle Rig,
11 minutes ago, ickyvicky125 said:I’m not looking at a specific headset but I’ll check out what you suggested to me. I have a pair of wireless ps4 platinum 7.1 headset I haven’t used yet. Would those be good enough or can I do better?
If you wan't audophile pro studio headphones they are stereo. What you need is HP's that will be loud and not sound like a toy and a good bass. I recommend these if you want mic on it too. You can also check out the SteelSeries 7.1 DTS HP's. They are very popular and will give you a good sound and not a toy sound. Here is the link SteelSeries 7.1 DTS HP's
