Stuck between two PSU's
Solved by minibois,
The RM750X has been serving me well (although I am just a normal user, so that anecdotal evidence is not much of use), but if you want the digital monitoring and the RMX styling you could go for an RMi PSU. Slightly different (yet still silver/black) label, but with monitoring.
Otherwise the difference between these two PSU's is the rating (Platinum vs. Gold in the HXi vs. RMX series respectively) and I believe the HXi has an extra 8 pin EPS (CPU) connector (useful if you wanted a higher end board, or a board in the Z390, or another HEDT platform, like Threadripper or Intel's offering in that price range).
