https://pcpartpicker.com/list/WJ7n4q
I want to know if this is a good PCPP list. The price is $750USD, but I can get it all for $650 at MicroCenter.
I plan on heavy gaming, no streaming or editing, just heavy gaming at 1080p 120hz or 4K 60.
Is this build worth it for $650?
Does the the motherboard have enough fan headers? I heard something about RGB headers, does the motherboard have those and will it work? Also will I be able to overclock the GPU & CPU?
Please feel free to make some changes if you think it’ll be better! I already have a 1TB SSD hence why I didn’t add one in the list.
Thanks!!
https://linustechtips.com/topic/1024069-first-pc-build-noob/
like csgo or overwatch? Because the RX 580 isnt doing near 120fps at 1080p in AAA games, let alone 4k 60.
Desktop benching:
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215841
That motherboard does indeed have RGB headers that should work with compatible devices
There are 4/5 fan headers, that should be plenty, 1/2 for your cpu, 2 for front or top intakes and 1 for exhaust (slight positive pressure, should help keep some dust out)
You can overclock on the B450 chipset and the CPU is overclockable
Don't know about the GPU, but I see no reason why not.
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215842
How about 1080p 60? I already have a 1080p60 monitor, I was planning on upgrading up to a better monitor but I guess I won’t be needing to upgrade; because the GPU won’t be able to get those results. Thanks!!
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215856
Awesome! Thank you for helping!
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215860
5 minutes ago, Ansuex said:
I would go with a Ryzen 5 2600 and maybe spend a bit more money on a quality power suppy.
But all in all a nice build :) I would personally not buy the RX580 and go with a second hard graphics card or a new RTX2060 about 50% faster for 100$ more.
Thanks for the advice!!
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215862
1 minute ago, Ansuex said:
The price in his pricepicker shows close to 300$ so even less then 100$ extra :)
https://pcpartpicker.com/product/PTfmP6/powercolor-radeon-rx-580-8gb-red-devil-video-card-axrx-580-8gbd5-3dhoc
*cough *cough
totally havent had an overview of the pricing of these things for like 6 months
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215863
1080p 60's right where it's supposed to do
Desktop benching:
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215866
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Amazon)
Motherboard: ASRock - Fatal1ty B450 GAMING K4 ATX AM4 Motherboard  ($103.98 @ Newegg)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($89.99 @ Newegg Business)
Video Card: PowerColor - Radeon RX 580 8 GB Red Devil Video Card  ($194.99 @ Newegg)
Case: Cooler Master - MasterBox Lite 5 RGB ATX Mid Tower Case  ($69.99 @ B&H)
Power Supply: Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($51.99 @ Amazon)
Total: $675.93
Generated by PCPartPicker 2019-01-21 08:21 EST-0500
fixed the build.
the PSU you picked out was awful. also changed some other bits while i was at it.
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215867
Total: $675.93
fixed the build.
Defeniatly better :)
RX580 for 200$ seems more fair too ?
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215871
Total: $675.93
fixed the build.
Thanks! But how was that PSU bad? It was 500w and semi modular. I’ll go ahead and buy the one you recommended me, but do you know exactly what cables are on it?
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215876
quality on the PSU you chose was awful and the semi-modularity is simply not worth it.
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($79.99 @ Newegg Business)
Memory: Patriot - Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory  ($60.98 @ Newegg)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB Video Card  ($399.99 @ Newegg)
Case: Cougar - MX330 ATX Mid Tower Case  ($49.98 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 650 W 80+ Bronze Certified ATX Power Supply  ($54.90 @ Amazon)
Total: $810.83
Generated by PCPartPicker 2019-01-21 08:28 EST-0500
id recommend this one minimum if you are doing 4K gaming.
the vega 64 isnt exactly quiet. but it is rather cheap atm and a very good deal.
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215881
Total: $810.83
That GPU is way too expensive for me lol.
Do you know what cables are on the PSU you recommmended me?
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215890
everything you are going to need.
but it is 2 8 pin connectors for the GPU and 1 8 pin for the CPU. then in addition youve got the usual.
essentially everything you will need
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12215895
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.57 @ Newegg)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($92.99 @ Newegg)
Storage: Samsung - 860 Evo 250 GB 2.5" Solid State Drive  ($57.99 @ Amazon)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: XFX - Radeon RX 580 8 GB GTS XXX ED Video Card  ($189.89 @ OutletPC)
Case: Corsair - 100R ATX Mid Tower Case  ($49.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($24.99 @ Newegg)
Total: $755.30
Generated by PCPartPicker 2019-01-21 09:33 EST-0500
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12216024
Just now, pino2000 said:
all that you will require.
be that as it may, it is 2 8 stick connectors for the GPU and 1 8 stick for the CPU. at that point what's more youve got the standard thing.
basically all that you will require
I mean. I addressed this allready........
Also i think you quoted the wrong thing.....
https://linustechtips.com/topic/1024069-first-pc-build-noob/#findComment-12216421
