External power button?
Go to solution Solved by aezakmi,
in the users' mind everything can be done with an USB port, I wonder why
you could go into the BIOS setup and enable the "power on via keyboard" option, that way every time you press return or click the mouse it'll turn on
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1023409-external-power-button/#findComment-12210243
because the U is for universal :P
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1023409-external-power-button/#findComment-12210350
How about you just don't turn it off?
Just leave it running and turn the monitor off when you're not using it.  When the pc idles, the power consumption is very low, especially for a hp slimline... typically around 30-50 watts. That's around 5-10$ a month in electricity.
https://linustechtips.com/topic/1023409-external-power-button/#findComment-12210357
This option only works if your Bios has it or you own a Ps/2 keyboard/mouse....
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1023409-external-power-button/#findComment-12219688
