Best Thin Bezel IPS Panel under $170?
Mostly fps gaming and point & click. Not alot of leg room for a small budget and my strong preference for the thin bezel, I know but I'm hoping for the least glow and ghosting possible for the price. Give me your best suggestions!
I was looking at these but I'm not sure which one...
Acer H236HL bid 23-Inc
AOC IPS i2367Fh 23-Inc
NZXT H440 l Inel Core i5-4670K l Z87-GD65 l MSI 780 Twin Frozr l Kraken x60 l Corsair RM 650 l Seagate Barracuda 2 Tb l Corsair Force GS 128 Gb l Teleios Sleeving l Acer H236HLbid l Corsair K70 Anodized Black l Roccat Kone Pure Color
https://linustechtips.com/topic/102330-best-thin-bezel-ips-panel-under-170/
I have the first monitor you mentioned I love it so much, the thin bezel is amazing! it is an incredible monitor, nothing more I could have asked. Hope this helps, also I has no problems with it :)
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
+1 for the Acer. Reviews for the AOC were generally poor IIRC.
Also, check out the Dell. It is a good deal.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
The AOC one has a very thin bezel. They do try to trick you a bit, so you'll want to see some reviews but it's pretty thin.
http://www.amazon.com/AOC-i2367Fh-23-Inch-Screen-Monitor/dp/B009V8F700/ref=sr_1_2?ie=UTF8&qid=1389749552&sr=8-2&keywords=aoc+ips+monitor
CPU: 5820k 4.5Ghz 1.28v, RAM: 16GB Crucial 2400mhz, Motherboard: Evga X99 Micro, Graphics Card: GTX 780, Water Cooling: EK Acetal CPU/GPU blocks,
240mm Magicool slim rad, 280mm Alphacool rad, D5 Vario pump, 1/4 ID 3/4 OD tubing, Noctua Redux 140/120mm fans. PSU: Evga 750w G2 SSD: Samsung 850 Pro 256GB & Seagate SSHD 2TB Audio: Sennheiser HD558s, JBL! speakers, Fiio E10k DAC/Amp Monitor: Xstar DP2710LED @ 96hz (Korean Monitor) Case: Fractal Node 804
Ah, good to hear personal experience. May I ask what games you typically play on it and how you feel about the glossy screen?
The matte finish is what drew me to it next to the thin bezel. Yeah I understand both of these models have this faux-thin bezel. I still like them.
I play BF4,L4D2 on it at the moment oh and I have my PS3 hooked up to it which I play COD on it (Don't hate just testing things out lately) and I love the glossy screen is super reflective :c but I don't notice it in games. The colours it gives are amazing and only with a 5ms response time, nothing more I could have asked for. One of my most favourite purchases. :D
That dell has a pretty obnoxious white stand, could it be much better than the acer performance wise?
