Hey guys,
I was looking at used systems to be able to play minecraft do some basic tasks.
I found a lot of systems on the used market foor under 100$, they include an i5 2400 or 3340 with intel graphics and 4gb ddr3.
are these systems worth it? Would they run minecraft at 100+ fps if I add ram?
or should I look for other used pc’s?
Thank you!
https://linustechtips.com/topic/1023241-looking-for-100-system/
Just now, Achilles said:
I can spend around 200 but what should I be looking at then? I have very basic hardware knowledge :/
Essentially a 3rd gen i5 desktop for about 100$. 50$ new PSU (corsair cx 450/550 (2017)) and 50$ towards either an hd7950 or hd 7970.
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209039
I found this system for 150 euro’s :
Dell Optiplex 7010
i5 3470 3,2 GHz
240 GB SSD Kingston (new)
or 500 GB HDD (- 20 euro)
4 GB RAM or 8 GB RAM ( if 8 GB +20 euro)
AMD Radeon HD 7500 series displayport en DVI
dvd-rw
Windows 10 pro
6 × USB 2.0
4 × USB 3.0
2 × displaypoort
VGA
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209040
Should I check which mobo the pc has before buying a gt 1030? Or do they fit on every mobo?
They fit on every motherboard with a PCIe x4/x8/x16 slot. AGP slots do not work, though those are from 2002-2007 so you don't really need to worry.
Probably the i5 3340 or i5 2600, plus an SSD and a GT 1030 (or a GTX 1050 or 1050 Ti if you can spend more, none of these need a PCIe power cable). Quite cheap little gaming machine. I would highly recommend getting another 4GB of DDR3, which should be pretty cheap (10-20$)
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209041
Dell Optiplex 7010
i5 3470 3,2 GHz
dvd-rw
Windows 10 pro
6 × USB 2.0
4 × USB 3.0
2 × displaypoort
VGA
Ask for 8GB of RAM (it's really going to improve your performance, don't go for the 500GB HDD as HDDs are pretty slow nowadays) and get a used GT 1030 or HD 7700/7790.
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209046
Yea ill look into that. If I would get 8gb that means im paying 20$ for 4gb so ill probably just go for 4gb and buy and 8gb stick for like 20 bucks. I mean I dont need something that boots up in 10 seconds, do you think the SSD or HDD would make a big difference in actual gameplay?
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209057
Found a HD 7970 for 30 bucks, worth it?
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209067
SSDs are one of the best things you can buy. In fps, nothing will be improved really. In loading times, it will be drastically improved if your game takes 2-3 minutes to load.
Apps launch instantly, login takes nothing, no noise at all, it's perfect
It's usually around 90-120$, ridiculously low ones on eBay or other used markets are always a scam. GT 1030s run for 30-40 bucks used, get one
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209085
Yea, ill probably get a system first and then start looking for a gpu, I can only find gt1030’s for like 80 bucks :/ I got a guy who wants to sell his pc (i5-4590) for 100$ to me, Im guessing a 4th generation i5 is beter than a 2nd or 3rd? I mean its the same price
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209129
It is.
What are the specs?
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209132
1 minute ago, NunoLava1998 said:
It is.
What are the specs?
All I know for now is that its a i5-4590 with 4gb ram (dont know which type) and 500hdd, i asked for which version of windows is installed, what type of ram and if theres a gpu installed (not really needed since ill be buying a new one)
https://linustechtips.com/topic/1023241-looking-for-100-system/#findComment-12209136
