Single or dual channel ram?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208579
47 minutes ago, Rhino-Boi said:
I have recently bought a rtx 2070. And I have a i5 7400. I want to know how much bottleneck I should expect from games
You should still be able to reach 1080p 60Hz without troubles.
I wouldn't be pushing something like 1440p or 1080p 120+Hz with that kind of setup, though. What motherboard and PSU do you have?
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208604
the bottleneck's pretty significant, see if you can get another stick of ram of a i7 used.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208614
1 minute ago, Rhino-Boi said:
i have a b250m plus board and 650 watt corsair psu. what kind of change would i need to make to get higher refresh rates @Crunchy Dragon
You'd probably want an i7-7700, as that would alleviate the bottleneck. I don't know if it'll eliminate it entirely, but it'll definitely make it better.
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208623
18 minutes ago, Rhino-Boi said:
Single
My brother has single channel DDR4 2400 and a 7400 with a 970, sees a bottleneck sometimes. I don't think a quad core does so well with a 2070.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208637
I don't see how this ties into your RAM question at all.
The 7400 is kind of just a weak CPU in general, a 7600K would be better, but a 7700K is way better than either one.
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208642
Just now, Rhino-Boi said:
whats the difference between the 7700 and the 7700k other than overclocking
thats the difference
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208652
Dual channel helps in CPU bound tasks (obviously a lot more on Ryzen but still, single channel bandwidth is not so high)
Primary PC:
PSU tier list
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208803
I'm curious to see if the problem would persist with a better CPU such as the 7700, though...
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208807
7700K is a slightly better CPU, and is unlocked.
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208809
The 7700 would pick up performance regardless of the single channel, but getting dual channel and an i7 is recommended.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1023186-bottleneck-help/#findComment-12208860
