Welcome to the forums Yosty! :D That's a bit warmish, nothing to be concerned. What are the temps when under full load?
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204037
1 minute ago, Yosty said:
Thank you very much :) Under load it hits 75-80 gets no higher.
On a dark rock pro 4, you would only see those temps overclocked. What's your OC?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204054
4.3ghz
That would be stock clocks, which seems to indicate something is not quite right. While 80 celsius as a max load temp is safe, I have overclocked a 10 core i9 on a drp4
Primary PC:
PSU tier list
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204060
Would this suggest me not mounting the CPU Cooler correctly? or would anything else play into this?
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204065
Just now, Yosty said:
All cores are around 65-80C under aida64 however cores jump up and down temps 10C+ every second.
It's at stock which does indicate that maybe the thermal paste was applied wrong or something idk, but it won't harm your CPU it'll just keep it at stock and it can't oc
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204067
That would be my first guess. Coffee lake systems are too young for a dried thermal paste.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204071
Way to hot for that CPU cooler.  You likely do not have it mounted correctly, or the thermal paste isn't correct or a combination of both. @Yosty
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204072
You should be idling in the low to mid 30c and hitting max 70c on that CPU cooler just understanding how things work (but having no experience with those two items in tandem)
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204075
@Tristerin @fasauceome Please can you suggest a brand of thermal paste to use as I am absolutely clueless.
A good go to is Arctix MX-4, cheapish and effective. Although maybe some tightening is all you need, the stock paste would have been sufficient.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204092
The idle temp of 50c is no good.  Something is off...….  I would personally take out cpu clean thermal paste on it and the HS and apply paste again and make sure you properly tighten the cooler.  We don't want you to chip the motherboard but make sure its tight,,,,   50c idle is suspect....
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204216
What motherboard are you using? Are you using default motherboard settings?
What are ambient temps?  Have you tried reseating the cooler?
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12204395
Update - I was stupid and unplugged my my back case fan when I was reseating something in my PC. I did reseat my CPU cooler anyway as I had bought the stuff, now getting 30-35 at idle and 65-70 at full load.
Thank you everyone in this thread that helped.
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12218084
Open Task Manager, sort the CPU to the highest usage, see if there is a sneaky program/application is running which raise the CPU usage while you are doing nothing as you might think it is idle, but actually it's not.. and end the task.. Otherwise you have to do something more..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
https://linustechtips.com/topic/1022713-strange-cpu-temps/#findComment-12219678
