Mate of mine is building a rig in the next month or so draft specs belowww
Budget £800-900
Fractal R4 windowed
Gigabyte G1.SNIPER Z87
4670k
CM Hyper 212 Evo
8GB Corsair Vengeance
GTX 770 GigabyteWindforce3 OR EVGA ACX
Corsair CS650M
1TB Seagate Barracuda
SSD coming after probably Samsung EVO
Comes to around £825-£830
What do you think, hes coming from some old dual core and a 9600GT so a pretty extensive upgrade.
https://linustechtips.com/topic/102227-build-for-a-buddy/
What's the system being used for?
'coming soon'? Are the parts already ordered?
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367076
Because the Define R4 has a window in this case I'd recommend the ACX 770. I think it looks a lot better than the Windforce, though Windforce does perform a better and runs cooler/quieter.
CPU: 5820k 4.5Ghz 1.28v, RAM: 16GB Crucial 2400mhz, Motherboard: Evga X99 Micro, Graphics Card: GTX 780, Water Cooling: EK Acetal CPU/GPU blocks,
240mm Magicool slim rad, 280mm Alphacool rad, D5 Vario pump, 1/4 ID 3/4 OD tubing, Noctua Redux 140/120mm fans. PSU: Evga 750w G2 SSD: Samsung 850 Pro 256GB & Seagate SSHD 2TB Audio: Sennheiser HD558s, JBL! speakers, Fiio E10k DAC/Amp Monitor: Xstar DP2710LED @ 96hz (Korean Monitor) Case: Fractal Node 804
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367082
Looks are subjective.
 edited, meant as is in a little while after the build
Why not get it now? What's the budget? Use of the system?
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367087
Added to OP
Ahem--third time I'm asking now...
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367097
A ssd is very doable: http://uk.pcpartpicker.com/p/2Bfg4
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367121
Its not that he cant afford it more the price per GB he has an issue with
Tell him to deal with it. 120GB is plenty for what he needs. You're not supposed to put anything but your os and programs on the ssd anyway.
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367133
Such sass
It did take the third time before you answered... :rolleyes:
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367144
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367152
If he wants to go for the 780, this has a bit more headroom for the budget: http://uk.pcpartpicker.com/p/2BfxH
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367166
PCPartPicker part list: http://uk.pcpartpicker.com/p/2Bfz2
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£167.99 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£23.90 @ Ebuyer)
Motherboard: MSI Z87-G45 Gaming ATX LGA1150 Motherboard  (£107.84 @ Scan.co.uk)
Memory: Patriot Viper 3 8GB (2 x 4GB) DDR3-1600 Memory  (£59.99 @ Amazon UK)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk  (£70.19 @ Amazon UK)
Storage: Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard Drive  (£63.94 @ Aria PC)
Video Card: Asus GeForce GTX 770 2GB Video Card  (£239.90 @ Amazon UK)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  (£73.98 @ Amazon UK)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£93.98 @ Dabs)
Total: £901.71
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-14 20:19 GMT+0000)
 Here 904 with an ssd. And fully sli ready. and 2tb.
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367175
I actually changed it to a 290 because it was really close to the limit of the budget
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367184
Not been overly impressed with the R9 series tbh loved the 79xx's but these R9s... not so sure
Well whatever suits you. These are all just suggestions.
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1367236
Other than the 290(x), the r9 series is just a 7XXX series rebrand with better coolers.
https://linustechtips.com/topic/102227-build-for-a-buddy/#findComment-1376293
