Hello,
I recently built a system with Corsair Vengeance RGB RAM and an ROG Strix 1070. I wanted to be able to control the RAM and GPU's rgb in sync so I went to the ASUS website and downloaded the latest version of aura sync. I immediately open it and I am surprised with a less up-to-date looking aura sync than I am used to (Screenshot below). I start to mess around with it a bit and the RAM rgb is working flawlessly. The GPU, on the other hand, is not. The rgb effects are laggy and the top ROG logo on the GPU will only light up three colors: red, green, and orange. If I change it to any other color, the light will simply go blank. I noticed on YouTube videos that the card is supposed to light up all colors, but the top portion on mine is not. And no, I dont want to use the GPU lighting software it came with because I want my RAM in sync with my GPU. Any help is appreciated.
Thanks, Landon
https://linustechtips.com/topic/1021834-asus-aura-sync-problems/
That's what you are doing wrong.
The vengeance RGB ram is incompatible with aura sync.
You need ICue to control the RGB on them.
Are you sure your GPU fully supports aura sync?
It might not, and this could be causing issues
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
1. The ASUS forums states that Aura fully supports corsair vengeance rgb
2. My GPU literally says aura sync compatible on the box
Yes it is "officially" supported.  I know they added it recently though.  Maybe they're still working the kinks out?
Not sure why the GPU wouldn't sink perfect.  Its an Asus product..
I'd double check I downloaded the right version of Aura Sync
