NEED HELP // Programs unable to write files in documents
Solved by RokasOnline,
1 hour ago, Radium_Angel said:Before you run the program, right click on the icon and choose "run as administrator", see if that helps/solves anything. Report back.
Tried it, doesn't help
Edit: It is because of the safe files, secured folders option in my BitDefender... Turned it off and it's fixed, wasn't Windows problem after all.
