Hey guys i have a Question a good friend of mine offerd me 2x GTX 1070 ti founders Edition (i love the style from These Cards sooooo much) for 500 euros (580 USD) so my Question is do you think i should buy those two Cards and run a SLI Setup or should i just buy a Radeon VII (i wait till the benchmarks tho)
https://linustechtips.com/topic/1021205-need-some-help/
I'd probably buy them both and then flip one of them or just buy one for 250.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/1021205-need-some-help/#findComment-12189718
my fear is that the GTX 1070 Ti just isnt enough anymore :/
and btw the founders Edition style, will the rtx series get a Version that Looks alike ? (i just love this designe :) )
https://linustechtips.com/topic/1021205-need-some-help/#findComment-12189728
RTX founder editions look pretty different, they have dual fans now. Well I'm not sure what monitor you have and with what settings you want to play which games, so I can't really tell you if it'll be enough.
My System:
https://linustechtips.com/topic/1021205-need-some-help/#findComment-12189735
2560 x 1440 and i want to Play some new games that will come out this year like shadow die twice :/ that was my main reason too upgrade so i just woundered if SLI 1070 ti would do alright
https://linustechtips.com/topic/1021205-need-some-help/#findComment-12189745
