is freedos compatible with all hardware regular DOS is supported by?
Solved by WereCatf,
1 minute ago, firelighter487 said:can i use freedos on it? will that work?
Almost certainly, yes.
Theminecraftaddict555 ·
Posted in Graphics Cards0 -
1
4
Minystreem ·
Posted in LTTStore.com Merch4 -
Sveeno ·
Posted in LMG Sponsor Discussion0 -
3
1
play_circle_filled
Latest From Linus Tech Tips:
The Most Awkward Upgrade…. AMD $5000 Ultimate Tech Upgrade
