-Moved to New Builds and Planning-
PCPartPicker isn't flagging any problems with that, I'd say it's fine.
https://linustechtips.com/topic/1020351-will-it-fit/#findComment-12182568
The gpu is a standard sized, i think it will fit.
https://linustechtips.com/topic/1020351-will-it-fit/#findComment-12182594
3 hours ago, Siddhant Mishra said:
Hey guys will a sapphire rx 580 8gb nitro+ oc fit in. A q300l case?
yeah, it will fit.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1020351-will-it-fit/#findComment-12182925
