Ive been playing quite a bit of battlefield 4 and I noticed plenty of times after the patch on January 13th that when I die in a gun fight the player who killed me has a health of 0.
Anyone know why this is happening. Is it from this recent patch or has it happened for quite some time?
https://linustechtips.com/topic/102032-bf4-problem/
This can happen due to rounding if you do 99.5+ percent damage but not quite 100.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/102032-bf4-problem/#findComment-1364537
and when he dies, you get a kill assist of 100 points. Same like in bf3.
  • CPU i5 3570k - 4.0 Ghz | Motherboard Intel DZ77SL50K | RAM Corsair Vengeance 4GB 1600 BUS DDR3 4GBx1 | GPU 2x Sparkle GTX 570 OC editionCase CM 370 EliteStorage Seagate 1TB 3.5" SATA HARD DRIVE 64MB CACHEPSU Cooler Master GX series 550W (80+ bronze)Display(s) Samsung 46' series 5 TV(1080p), Dell 20' (1280x1024)Cooling 3x Corsair SP120 QUIET EDITION HIGH STATIC PRESSURE 120MM FAN TWIN PACKKeyboard DELL original default keyboardMouse A4 Tech x2 800dpi | Sound On board~!
https://linustechtips.com/topic/102032-bf4-problem/#findComment-1364543
The 0 health glitch wasnt always there before this patch, the 1% was... everytime they fix a bug, an old/new one is introduced... how do they even keep their jobs...
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/102032-bf4-problem/#findComment-1364551
Dis^^
Dat 0 health glitch. Been there since BC2 lmao.
No glitch!
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/102032-bf4-problem/#findComment-1364553
