best budget surround sound System?
Olli_
Hi.
I am currently looking to purchase a new sound system for watching films and games on the tv. I have a budget od around £250. I would prefer it to be wireless if possible.  I dont really know alot when it comes to this stuff. I have a sound bar that i use at the moment but i have moved a my stuff into a bigger room so would like to fill the room more with the sound. And i was going to use it for my pc now instead. Any options or advice would be greatly appreciated.
Thanks
I'm a big enthusiast of properly-done audio for movies, but to be totally honest most people are pretty happy with a good sound bar + smallish subwoofer. Having never owned one I can't recommend any specifically but I'm sure you can google "best sound bars" or similar to find pricing in your country for preferred models.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
We're using the Yamaha YAS-207 at our TV.
It sounds absolutely amazing for it's money, has surround (6 Speakers + wireless subwoofer), connects via HDMI ARC, has Bluetooth, can be configured using the app for iOS- and Android-Devices.
It costs 229 pounds at amazon.co.uk. Worth it's money! :)
https://www.amazon.co.uk/Yamaha-YAS207-Surround-Soundbar-Virtual/dp/B0741CD18V/ref=sr_1_1?ie=UTF8&qid=1547223655&sr=8-1&keywords=Yamaha+YAS-207
It has HDMI-in (via ARC on the tv, turns on when the TV turns on), analog in, optical in and even an HDMI-out.
On 1/10/2019 at 1:56 PM, Olli_ said:
Hi.
Thanks
Have a look at logitech z906. just dont use the speaker wire they come with - its not "shielded" and will create a fuzzy noise in the speakers. buy a 100ft amazon basics reel of the stuff. for the reel and z906 it would be about 220 pounds. :)
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
