Wireless for gaming?
Go to solution Solved by DGPC,
There are three iphones, and two laptops on the wifi. Both laptops are just browsing web and the phones are basically doing nothing. It is about four walls between my room and the router. Yeah these are the speeds I usualy get but the upload speeds go down to 1mb/s sometimes. I only have to reset the router about once every two months if I am lucky. Does this seem fine?
Looks all good, you should be fine.
My Dad want me to route a a cable box, telephone, and router to my room. I dont know why I am not allowed to just route a cat6 cable and take the router. Anyways is a wireless PCI card / USB wireless stick okay for FPS gaming like Counter Strike and BF4? Budget is $20 for one, please link me to one. We have cable and it all is hooked up with a Coax cable if that changes anything.
https://linustechtips.com/topic/101902-wireless-for-gaming/
depends on how good your wifi signal and internet is. with mine its fine but some have worse internet.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/101902-wireless-for-gaming/#findComment-1362574
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/101902-wireless-for-gaming/#findComment-1362581
That speed, on its own, should be sufficient. It's all the other factors that may hurt your gaming like: How many other people are using the Wifi? How strong is your signal? Is the speed you are getting right now consistent 24/7? Do you always seem to have random disconnects and have to restart your router? Things like this can be more important then mere speed.
https://linustechtips.com/topic/101902-wireless-for-gaming/#findComment-1362615
PCI is OK, Don't bother with USB. Latency issues..
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/101902-wireless-for-gaming/#findComment-1362702
https://linustechtips.com/topic/101902-wireless-for-gaming/#findComment-1362744
https://linustechtips.com/topic/101902-wireless-for-gaming/#findComment-1362955
