3 minutes ago, Klemmbrett said:
Running any OC`s ? How is your fan curve configured ? Do you use any software for controlling cpu fans ? How is the usage when you go away ? Maybe some services running when you do nothing (updates, virus scans or whatever else)
No OC but how can I configure fan curves? Also no softwares...
Probably Windows is doing some work in the background!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
1 minute ago, HypedKid said:
I just opened task manager and left it...
And?
Scan with Malwarebytes
You think viruses can cause that?
They could
11 hours ago, HypedKid said:
So I found that every time I leave it, some softwares are running like windows antivirus and is it possible to turn it off? Also im using nzxt cam and it shows that my cpu cooler spins at about 1600 prm nearly max
You can see what service/application is causing what load so what is it.
14 hours ago, HypedKid said:
So I just noticed that when I leave my pc for few mins and come back cpu temps are about 50°C ,but when I move my mouse, temps goes back to 35-40°C.... What's bad with it? How to solve that?
13 hours ago, HypedKid said:
You think viruses can cause that? Maybe... I'm using only windows antivirus
Could be a trojan. Run malwarebytes like Constantin said.
I googled around a bit and read someone with the same symptoms. (high temps at idle, drops when active)
Apparently they needed to redo the thermal paste. Doesn't make sense to me.
It didn't find anything....
