My monitor is 144hz but it says it’s 60hz?
Ben a cava
CPU: Ryzen 5 2600 @ 3.2Ghz
Motherboard: MSI B450 Gaming Pro Carbon AC
RAM: Team Vulcan DDR4 16GB (2x8GB)
GPU: Zoatac Gtx 1070 8GB
Case: CoolerMaster Masterbox Lite 5 RGB
Storage: 2TB Toshiba HDD, 120GB WD Green SSD
PSUGigabyte P650B
Use a Display Port cable.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
2 minutes ago, Ben a cava said:
HDMI cables doesnt always support 144hz 1080p...ideally you need a display port cable for that.
HDMI 1.4 and newer technicaly support it...but it depends on the cable and the HDMI in and out on your graphics card and monitor...in short...just get a display port cable.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
I have display power but the monitor doesn’t have the slot
PSUGigabyte P650B
I have one but I thought doesn’t fit into the monitor
PSUGigabyte P650B
Wait, your monitor doesn't have displayport? What the fvck?
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
I think you need DVI Dual link, then.
8086k
aorus pro z390
evga 3070 ultra
What’s that ahha
PSUGigabyte P650B
yes, this.  I was wrong about Display Port, the monitor doesn't have one.  Kinda shocking but yeah.
OnePlus:
Other Tech:
Reckon I could return it as I have bought it recently but have opened all the packages with the cables in it
PSUGigabyte P650B
Will dual dvi  link work in a normal dvi slot
PSUGigabyte P650B
Yeah, it's a standard but a lot of regular DVI plugs are missing pins that dual link have. Just buy a dual link cable.
8086k
aorus pro z390
evga 3070 ultra
Okay thanks
PSUGigabyte P650B
I assume this works CSL - 2m high speed DVI to DVI cable | Dual Link 24+1 | gold-plated contacts | HDTV resolution up to 2560x1600 | 2x ferrite core | tin-plated OFC copper conductor | x.v. colour https://www.amazon.co.uk/dp/B00MO7TNBY/ref=cm_sw_r_cp_api_i_VFpnCbKABYDDF
PSUGigabyte P650B
looks good to me
8086k
aorus pro z390
evga 3070 ultra
