Hello! Recently ive been having a problem, my gpu, a gigabyte geforce gtx 1050 3 gb, my drivers are all up to date and it works perfectly! after about 3 games to "Warm it up" in fortnite. this might just be fortnite, but my drivers are all up-to-date and another intresting thing the fans do not spin, as you can see by the title. sometimes my whole computer will crash even if im just on the web or anything like that. idk what i should do, this might be caused because my fans dont spin, im not a huge nerd so if anyone has any solutions and you have the time, please tell me what i should do, i cant find anything online so i resorted to here!
Thank you for your time
-WASDIsKing
https://linustechtips.com/topic/1018569-gpu-fan-not-spinning/
What's your GPU tempature? When the tempature is low enough the fans don't start to spin.
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1018569-gpu-fan-not-spinning/#findComment-12165626
iirc, at least on my GTX 1060 6GB, the fans will not spin up unless the gpu goes above 55c, to be quiet unless put under load. Keep in mind if you download MSI Afterburner, you can set a manual fan curve to mitigate this- if you're worried.
Otherwise, it's built into the hardware to not turn the fans on unless it has to.
https://linustechtips.com/topic/1018569-gpu-fan-not-spinning/#findComment-12165635
