7 minutes ago, LukeSavenije said:
both are great top of the line phones, you could go a bit cheaper with the same specs, you should know that. the difference between these two come down to personal preference
I realise I dont need to spend quite as much but screen size is the main reason for the upgrade and im looking for something thats at least 6.4 inches. Im also considering the mate 20 X with the 7 inch display and smaller notch
https://linustechtips.com/topic/1018237-mate-20-pro-or-note-9/#findComment-12162976
Huawei has a more Apple feel with it's Android skin (EMUI) and If you don't mind the bloatware from both Huawei and Samsung.
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
https://linustechtips.com/topic/1018237-mate-20-pro-or-note-9/#findComment-12162983
then I highly recommend to look into the oneplus 6t
the mi8, pocophone, oneplus 6 and zenphone 5z are also worth to mention, but those are 6,2 inch.
emui and miui are simulair, you like it or you don't
https://linustechtips.com/topic/1018237-mate-20-pro-or-note-9/#findComment-12162985
Of the two, I'd prefer the Mate 20 Pro.  Better overall camera quality (Samsung has an over-sharpened, cool-hued look I'm not a fan of) and less tendency to bog down over time.
Out of curiosity, if screen size is your main beef, why not spring for an iPhone XR or (if you can swing it) XS Max?  Both over six inches and definitely easy on the eyes.
https://linustechtips.com/topic/1018237-mate-20-pro-or-note-9/#findComment-12164325
I’m currently using a XS (selling it tomorrow to fund the replacement) and getting frustrated with how small the screen is. The larger iPhones do nothing to fix this as all they do is enlarge the content on the screen instead of showing more. It’s a poor use of the screen and when a XS Max is so much more than all of the androids I’m interested in it really doesn’t make sense to go for one. I would much rather go for a note 9 or mate 20 where the large screen is used to its full potential.
I’m currently trying to talk myself out of the mate 20x, 7.2 inch display with a dew drop notch and 5000mah battery is very tempting. Especially as its 100-150 cheaper than the mate 20 pro (820 as opposed to 900-1050 for the pro)
https://linustechtips.com/topic/1018237-mate-20-pro-or-note-9/#findComment-12165391
