Suggestions for a UPS battery backup?
3 hours ago, TrinityHigh said:Hi there,
I am looking at getting two UPS battery backups for my two setups that I have in different rooms:
One for my gaming PC (9900k + 1080) and three 24" monitors.
My other setup is an iMac 27", 6 drive thunderbolt raid storage, and my router+modem combo.
Both setups are currently on height adjustable desks so right now everything is powered by a 15' 6 plug surge protecter power bar. This way I only have 1 cable that is coming down from the desk as everything else is cable managed under the desk.
Thanks in advance
Something like this should be more than enough for each system individually, you can set up to the larger 1000VA (600W) unit if you plan to use a lot of peripherals or high current devices and slightly longer run time.
https://www.cyberpowersystems.com/product/ups/cp850pfclcd/
https://www.cyberpowersystems.com/product/ups/cp1000pfclcd/
-Moved to case and power supplies-
