Okay so, I’m a complete noob when it comes to this. I need to rework this build. I would like to keep my CPU, GPU, RAM. The case, PSU, fans and MOBO need to be changed.Someone said something about the case being too big for the motherboard, idk I just want it to look *juicy*. So if someone could take time out of their lovely day to help me change this build and make it wet, I’d appreciate it a lot. Thanks!
https://pcpartpicker.com/list/6wPXq4
https://linustechtips.com/topic/1018063-my-first-pc-build/
The things I would upgrade would be the cpu and ram. Everything else in there looks fine for what you have.
The case is ATX but being "too big" isnt going to hurt it. Though I can't imagine those fans are too great.
EDIT: Your case is meant to fit that motherboard
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161319
I’m going to overclock the RAM and CPU, so I think it’ll be bad.
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161325
The VRM's on that motherboard don't have any heatsinks so yeah it would be a little rough overclocking.
Heres some changes:
Type Item Price
CPU AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor $164.89 @ OutletPC
Motherboard ASRock - B450M PRO4 Micro ATX AM4 Motherboard $83.88 @ OutletPC
Memory Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory $99.99 @ Newegg
Video Card MSI - Radeon RX 570 8 GB ARMOR MK2 Video Card Purchased For $0.00
Case Thermaltake - Versa H15 MicroATX Mid Tower Case Purchased For $0.00
Power Supply Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply $59.89 @ OutletPC
Wireless Network Adapter TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter Purchased For $0.00
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $448.65
  Mail-in rebates -$40.00
  Total $408.65
  Generated by PCPartPicker 2019-01-06 18:10 EST-0500
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161333
As far as a mobo change goes, get something like an Asus Strix B450-F.
For the case, you could get a Fractal Design Meshify C (or similar).
For the PSU, get a 550W~ 80+ Gold.
For fans, get Noctua if you don't care about color (best fans); or get pretty much any name brand fan (Corsair, Thermaltake, etc) if you care about appearance.
Here's a ink with parts: https://pcpartpicker.com/list/L38rsZ
The case comes with some fans (refer to the product page to see size and placement: http://www.fractal-design.com/home/product/cases/meshify/meshify-c) so you can get more and fill all the slots if you choose.
A larger case would actually benefit you if you are OCing your CPU. A larger case will have more space for airflow, helping with thermals.
But if you are OCing your CPU, I would also recommend that you upgrade your cooler. That Arctic one seems a little weak. A Cryorig H7 would be much better (pcpartpicker doesn't have pricing for it): https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=cryorig+h7&N=-1&isNodeId=1
The Plus version is just dual fans. The Lumi version is RGB.
Edit: The standard H7 does come with an AM4 mounting bracket, if you choose one of the others make sure they come with the AM4 kit (you can get it separate if it does not).
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161347
I would shoot for the Ryzen 3 2200G rather than the Ryzen 1300 and then get a board with a BF50 chipset rather than B350. The Ryzen CPU's come with good coolers as is so I would ditch the custom one you included and put some more money into the power supply. The VS series are cheap and I wouldn't feel good about running a RX 570 on one. Shoot for a CS or CX series 500 watt. I also noticed you don't have any storage included. Is that intentional?
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161358
4 minutes ago, BigDamn said:
OP already has this set up. They're looking to upgrade.
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161376
For the PSU, get a 650W~ 80+ Gold.
you're going overkill for the price... I'll just recommend this...
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161377
OP wanted to stay below $550. So I suggested a high quality case and CPU cooler. Motherboard shouldn't matter too much as long as he gets a B450 at least, and as long as the PSU is good that shouldn't matter either.
*GPU Test Bench*
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161386
yeah, and the vs isnt... and a vrm shield is kind of a requirement for gaming to me...
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161394
PCPartPicker part list: https://pcpartpicker.com/list/VvDq8Y
Price breakdown by merchant: https://pcpartpicker.com/list/VvDq8Y/by_merchant/
CPU: AMD - Ryzen 5 1500X 3.5 GHz Quad-Core Processor  ($144.99 @ Newegg)
Motherboard: ASRock - X370M Pro4 Micro ATX AM4 Motherboard  ($74.58 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8 GB (2 x 4 GB) DDR4-2800 Memory  ($54.99 @ Newegg)
Video Card: Sapphire - Radeon RX 570 4 GB NITRO+ Video Card  ($159.99 @ Newegg)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  ($41.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Wireless Network Adapter: Rosewill - RNX-AC600PCEv3 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($24.99 @ Newegg Business)
Case Fan: ARCTIC - Arctic F12 74 CFM 120mm Fan  ($6.99 @ SuperBiiz)
Total: $555.50
Generated by PCPartPicker 2019-01-06 18:31 EST-0500
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161414
Total: $555.50
What’s the difference of the Ryzen 3 1200 overclocked to 3.5Ghz and Ryzen 5 1500X?
sorry I’m a noob
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161421
sorry I’m a noob
The Ryzen 3 1200 is 4 cores, 4 threads
The Ryzen 5 1500x is 4 cores, 8 threads
Basically, more multi-tasking power.
*GPU Test Bench*
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161432
17 minutes ago, TheFishBucket said:
Oh I see.
Not the best analogy ever, but it might help you understand:
cores in a CPU is kind of like cylinders in a car engine.
a 4 core, 8 thread (2 threads per core) CPU would be like a V8 engine (2 cylinders per row). While a 4 core, 4 thread (1 thread per core) CPU would be like an Inline 4 engine (1 cylinder per row). And an OC would essentially be equivalent to turbochargers or superchargers in an engine, voltage would be intake/exhaust, and power consumption would be fuel economy/piston compression. Edit: an engine's RPM would be equivalent to a CPU's clock speed
I don't know a ton about cars, but I formulated this based on my limited knowledge
*GPU Test Bench*
https://linustechtips.com/topic/1018063-my-first-pc-build/#findComment-12161497
