so I'm currently building a custom loop for my system.  I went by ek's custom configurator and bought what they had recommended.  i began installing everything today to realize that they were wrong.  I have absolutely no clearance to install the 280mm rad on front and the 240mm rad on top.  Now I'm looking into a new case so i can finish this water cooling loop.  The new case must support a 280mm rad on the front and a 240mm rad on top.  The rads that i am using are EK's ce series with corsair ml pros on them.  i am also using  a ek x-res 140 revo d5 pump.  I dont wanna spend a ton of money on a new case as i have already spent enough money on buying all the parts.  The case i am currently using is the corsair 400c.  I would prefer the case to be white but if that isn't an option then so be it.  The only cases that i have looked at so far as being potential options are the fractal design meshy c and the next h700.  I really dont wanna spend 200 on the next but if its the only option that gives me what i want then ill have to go for it.  Also please try not to recommend any thermal take cases as i have had nothing but problems with there products in the past.  My parts are listed right below.  Thanks
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/1017281-need-suggestions-on-case/
Phantek Enthoo Pro M SE
Coolermaster H500P Mesh White
Lina Li PC-O11DW
Fractal Design Define R6 White
(Note, Meshify C will NOT work due to your GPU being too long to fit an AIO at the front)
