wait for their new cpus to release as they will have better performance.
EDIT:
These Numbers are just rumors but we should find out in the coming weeks.
https://linustechtips.com/topic/1017072-correct-cpu-for-2070/#findComment-12152416
If your focus is gaming the Ryzen 5 2600 is a solid alternative, Games always will prefer better cores over a bunch of cores as the greatest majority is still quad-core optimized.
So the Ryzen 7 1700 games a bit worse, and it's main point is for streaming, content creation and other stuff that requires the extra cores.
Now careful about going Ryzen 5 2600, it's a build that requires you to overclock it entirely, from memory to CPU in order to extract all it has to offer if you're scared of overclocking or simply does not want to I highly suggest the i7 8700 on a B360 instead.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1017072-correct-cpu-for-2070/#findComment-12152419
Well i want to game and stream it on twitch or youtube (something like that)
Btw thanks for your help and any other suggestion bcoz i will build it in april or may should i wait for better cpu's or?
https://linustechtips.com/topic/1017072-correct-cpu-for-2070/#findComment-12152436
EDIT:
Thanks!!
https://linustechtips.com/topic/1017072-correct-cpu-for-2070/#findComment-12152445
