could anyone help me out in chosing the right power supply for my components i will have
-ryzen 5 2600
-asus gtx 1080 strix
-case with 2*120mm fan and 1*200mm fan on the side
-i have dvd rw
-samsung evo 850 ssd
-WD Blue 500GB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 16MB
-patriot viper 2*4gb 3000mhz
-gigabyte b350 gaming motherboard
and i have 27'' 144hz monitor
https://linustechtips.com/topic/1016486-power-wanted/
10 minutes ago, Marijanusic said:
i think i found a midle ground for components that i need so i was wondering if anyone of you can tell me if its a good choice for said build
http://www.coolermaster.com/powersupply/masterwatt-lite-series/masterwatt-lite-230v-700w/
no, tier 4/d...
i would get a bit better. and there is no need for 700 watts, 500 or even 400 would be enough
https://linustechtips.com/topic/1016486-power-wanted/#findComment-12147907
no, that's shit.
Why do you want such low quality unit? Do you want to have Problems like random freezes/reboots and shutdowns or get a new PC every couple of years?
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1016486-power-wanted/#findComment-12151081
like I said there is a link to some of the sites is available to buy PSU-s I have 10 000 RSD so what do you guys recommend from here
https://www.gigatron.rs/napajanja  or
https://www.emmi.rs/konfigurator/proizvodi.10.html?categoryId=219
not much other choice here in serbia
https://linustechtips.com/topic/1016486-power-wanted/#findComment-12151118
That is the best option:
https://www.emmi.rs/napajanja-i-dodatni-ventilatori-napajanje-750w-fsp-fortron-hydro-g-hg750.11.html?productId=75614
But a bit over budget and 750W...
STAY AWAY FROM HYDRO GE!!111
The next thing that is somewhat Okish, probably is that:
https://www.gigatron.rs/napajanja/cooler_master_napajanje_mwe_gold_550__mpy5501acaag-151546
I don't know about Sama...
https://linustechtips.com/topic/1016486-power-wanted/#findComment-12151927
On 1/4/2019 at 10:06 AM, Marijanusic said:
i chose to go with this one Seasonic SS-620GM2
You got one of the shittiest "named brand" PSU that is on the Market right now. even EVGA Bronze would probably be a bit better than that.
If something goes wrong, the protection of that unit are just not there. Only OPP and maybe UVP on 3,3V and 5V but NOT 12V...
https://linustechtips.com/topic/1016486-power-wanted/#findComment-12156811
Looking at your specs, I'd play it safe with 500/550w although 400w would probably do it. There is no real need for wattage higher than 550w, however you may want to go a little higher to leave some 'wiggle room' for upgrades. As long as you choose something with a brand name/model no. and any level of 80+ certification, all will be good.
https://linustechtips.com/topic/1016486-power-wanted/#findComment-12186809
