Hi so I've narrowed down my choices of laptop, right now anyway, to a asus gl502v and an acer nitro 5.
The asus gl502v specs are:
I7 6700HQ
Gtx 970m
8gb ddr 4 ram
256gb ssd
1tb hdd
And the acer nitro 5 specs are:
I5 8300H
Gtx 1050 4gb
8gb ddr4 ram
1tb hdd
I think I'm more persuaded by the gl502v, however it is older and the nitro 5 has a better processor, but from what I've heard the nitro 5 has cooling problems. What do you think? Both the same price, yes used, no nothing else has come up at a similar deal yet. I'd likely upgrade to 16gb of ram at some point aswell
I'd use it for gaming but I have a gaming rig aswell that and school work, so would be carrying it around and you can usually find a plug socket although ok battery life would help.
Thank you
https://linustechtips.com/topic/1016357-cant-decide-on-laptop-help/
I7 6700HQ
Gtx 970m
8gb ddr 4 ram
256gb ssd
1tb hdd
I5 8300H
Gtx 1050 4gb
8gb ddr4 ram
1tb hdd
Thank you
I7 6700HQ
Gtx 970m
8gb ddr 4 ram
256gb ssd
1tb hdd
This one is the best by far.
CPU: Intel i7 6700K 4.5 ghz / CPU Cooler: Corsair H100i V2 / Board: Asus Z170-A / GPU: Asus Rog Strix GTX 1070 8GB / RAM: Corsair Vengeance LPX 16GB DDR4 3000 mhz / SSD: Samsung 850 Evo 500 GB / PSU: Corsair RMx 850w / Case: Fractal Design Define S / Keyboard: Corsair MX Silent / Mouse: Logitech G403 / Monitor: Dell 27" TN 1ms 1440p/144hz Gsync
Neither are good choices IMO
Lcoation? Budget? Preferred max weight in kg/lbs and min battery life in hours?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
