use sfp+ as LAN output pfSense and run pfSense in VM
Solved by Falconevo,
23 minutes ago, VictorN2990WX said:Hello
I am building a pfSense based router (parts have not arrived yet) andi wonder two things:
A) is it possible to run pfSense in a VM and pass the necessary NICs through?
B) Can i use a Mellanox sfp+ NIC as my LAN output (i got an sfp+ switch whit 4 sfp+ ports) (i still want to use standard Gigabit in as my WAN connection)
A) Yes, you can either attach the VM to a vSwitch with that interface assigned or perform PCI-Express device passthrough depending on what HyperVisor you are planning on using. Hyper-V, ESXi, KVM, Xen etc etc.
B) Yes, assign the device inside the VM it will likely be easier as a vSwitch if you want to keep that config
