Hey im about to build a system for myself for the first time and im asking for some opinions :)
Specs: sapphire vega 56 pulse
asus rog strix b450-f
ryzen 7 2700x
gskill 16 gb ddr 3200 trident z
thermaltake smart pro rgb 750W 80+ bronze
Would everything work fine together, and do you have any ideas of improvements?
https://linustechtips.com/topic/1016147-first-time-building-a-pc-need-help/
Why vega? Also wheres your case? Try Pcpartpicker, as that can help with compatibility. Also why the RGB power supply, it just gives a rgb underglow or a glow if you don't have a PSU shroud, I would recommend getting a better efficiency PSU for the same price with out RGB.
Current Gaming build:
Specs:
CPU: AMD Ryzen 7 3800x
CPU Cooler: Corsair H100i Platinum
Motherboard: ASRock X570 Taichi
Memory: 2x8GB Corsair Vengeance RGB Pro 3000mhz 15-17-17-35
Graphics Card: Geforce RTX 2080
Graphics Card Cooler: EVGA XC Ultra Gaming
Storage: 500GB Samsung 860 EVO, 1TB Western Digital Blue
PSU: Thermaltake Smartpower 750W
Case: Corsair 460x Black
Case Cooling: A mix and match of fans ?
Peripherals:
Monitor: HP 27ea
Keyboard: Corsair K70 RGB MK.2 SE
Mouse: Corsair Glaive Black
Headphones: Corsair HS60
Microphone: Blue Snowball Black Edition
"Gaming" Laptop: Apple MacBook Pro Mid-2012 with Nvidia Geforce Now
thanks first of all! and i had absolutely no clue i thought its kinda cool, and case would be SHARKOON - TG5 ATX Mid Tower Case, im just insecure about the ram working with the motherboard right now, and is vega certainly bad? i heard pretty good things about it, (i would use the system as a workstation/gaming pc)
Vega isn't horrible but you can get better performance per dollar. I'll throw this all in PC part picker and make sure it works.
Specs:
Peripherals:
Monitor: HP 27ea
Well depends on how much does it cost. Vega has come down in price quite drastically, you can find great deals these days.
Laptop: Acer V3-772G  CPU: i5 4200M GPU: GT 750M SSD: Crucial MX100 256GB
DesktopCPU: R7 1700x GPU: RTX 2080 SSDSamsung 860 Evo 1TB
Is this gaming focus?
If so go Ryzen 5 2600 isntead and use stock cooler to save up money in order to afford the Vega 64 instead (if you want AMD GPU) as it'll give you more benefits at gaming.
The Power Supply is not a very good choice, you only need 550w here so shop for a better quality one, you can check out alternatives (Tier 1 and Tier 2) in here:
Personal Desktop":
Luna, the temporary Desktop:
1 minute ago, synnx said:
i can get this system for like ~900-1000 euros right now
Does it include storage?
Specs:
Peripherals:
Monitor: HP 27ea
