PSU magic - explosion inside
Go to solution Solved by Bananasplit_00,
your PSU blew up, either it blew a fuse or it killed itself and probably some of the parts in the system. if this was a new system you should be able to get your money back at least
I tried to power up my pre-built system with a Float on FL450 (450W). At first, it didn't start up. Then, it started, but seem kinda slow so I let it run. I also heard a scratching noise from it's fan, but the fan didn't hit anything. I was looking at it when suddenly there was an explosion inside. It didn't fall apart, but it looked like a small lightning.
Here's the question: What did just happen, why and can it be repaired and how?
https://linustechtips.com/topic/1013923-psu-magic-explosion-inside/
Builds:
Buy a new PSU. A decent one, from the top 3 tiers of the PSU Tier List (google "LTT PSU Tier List").
Look at all the parts in the system, if anything is visibly burnt, melted, or fused that part is probably dead (unless it's just the plastic covering on the GPU or something like that).
Detailed pics might help with autopsy.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Just now, Betahuman said:
Oh wow, you opened it up.
Be EXTREMELY careful because touching one of those capacitors could literally kill you if it's still charged... I wouldn't mess around in there, it's a lot safer to just buy a new PSU for $30-50.
HOLA NIGHT THEMERS
OTHER TECH I OWN:
So it's actually time to kick it, huh? Could you give a good recommendation for a dude on a tight budget?
Where do you live?
HOLA NIGHT THEMERS
OTHER TECH I OWN:
