Maximum numbers python file reading help
Go to solution Solved by 0x21,
2 hours ago, DerpDiamonds1 said:
So with this solution can I have multiple high scores from the same username?
No, if you want to have multiple scores from the same user then this will work:
def printScores(n):
  with open('scores.txt', mode='r') as file:
    reader = csv.reader(file)
    # Create a list of tuples from the text file
    scores = [(row[0], int(row[1])) for row in reader]
  # Sort into a list of the top n scores.
  scores = sorted(scores, key=lambda score: score[1], reverse=True)[:n]
  # Print
  if len(scores) > 0:
    print("The top {} scores are:\n".format(n))
    pos = 1
    for name, score in scores:
      print("\t{}. {} with {}".format(pos, name, score))
      pos += 1
  else:
    print("There are no scores")
So I am trying to read from a file and display the top 5 scores, but I don't know how to do it. My formatting is like this:
Name, Score
My current code is:
import random
import re
def storeWinners(winner, winningScore, user1Score, user2Score):
   file = open("scores.txt", "a")
   file.write("\n" + winner + ", " + winningScore)
   file.close()
def finalDecide(user1Score, user2Score, user1, user2):
   if user1Score > user2Score:
      winner = user1
      winningScore = str(user1Score)
      print("The winner is", user1)
   elif user1Score < user2Score:
      winner = user2
      winningScore = str(user2Score)
      print("The winner is", user2)
   elif user1Score == user2Score:
      while user1Score == user2Score:
         user1FinalRoll = random.randint(1,6)
         user2FinalRoll = random.randint(1,6)
         user1Score = user1Score + user1FinalRoll
         user2Score = user2Score + user2FinalRoll
         winner = user1
         winner = user2
def rollDieWithPoints(user1, user2):
   user1Score = 0
   user2Score = 0
   for i in range(0, 5):
      user1Roll1 = random.randint(1,6)
      user1Roll2 = random.randint(1,6)
      user2Roll1 = random.randint(1,6)
      user2Roll2 = random.randint(1,6)
      user1Score = user1Score + user1Roll1 + user1Roll2
      user2Score = user2Score + user2Roll1 + user2Roll2
      def user1Points(user1Score):
         if (user1Score % 2 == 0):
            user1Score = user1Score + 10
            if user1Roll1 == user1Roll2:
               user1Roll3 = random.randint(1,6)
               user1Score = user1Score + user1Roll3
         elif (user1Score % 2 != 0) and (user1Score - 5 >= 0):
            user1Score = user1Score - 5
         else:
            print("I'm sorry there was an error, please try again later")
      def user2Points(user2Score):
         if (user2Score % 2 == 0):
            user2Score = user2Score + 10
            if user2Roll1 == user2Roll2:
               user2Roll3 = random.randint(1,6)
               user2Score = user2Score + user2Roll3
         elif (user2Score % 2 != 0) and (user2Score - 5 >= 0):
            user2Score = user2Score - 5
         else:
      print("For this round, user 1 got", user1Score, "and user 2 got", user2Score)
   print("Now for the end of the game")
def authentication():
    file = open("users.txt")
    text = file.read()
    user1NameInput = input("What is your name user 1?: ")
    re_res = re.search(r'^{}, (.*)$'.format(user1NameInput), text, re.MULTILINE)
    if re_res:
        password = re_res.group(1)
        user1PasswordInput = input("What is you password user 1?: ")
        if password == user1PasswordInput:
           print("Welcome to the game user 1, now for user 2")
           user2NameInput = input("What is your name user 2?: ")
           re_res = re.search(r'^{}, (.*)$'.format(user2NameInput), text, re.MULTILINE)
           if re_res:
              userPasswordInput = input("What is you password user 2?: ")
              if password == userPasswordInput:
                 print("Welcome to the game, now you can both play")
                 user1 = user1NameInput
                 user2 = user2NameInput
              else:
                 print("Wrong password, try again")
           else:
              newUsernameInput = input("That username is not in the system, would you like to create a new user by that name? (Y/N): ")
              if newUsernameInput == "Y":
                 file = open("users.txt", "a")
                 newUsernamePasswordInput = input("Please enter your password?: ")
                 file.write("\n" + userNameInput + ", " + newUsernamePasswordInput)
                 file.close()
              elif newUsernameInput == "N":
                 print("Okay, username incorrect, try again")
              else:
                 print("That is not an input, please try again")
        else:
    else:
          file.close()
       else:
    file.close()
def start():
   startingChoice = input("Do you want to play the game (1) or check scores (2)?: ")
   if startingChoice == "1":
      authentication()
   elif startingChoice == "2":
      file = open("scores.txt")
      text = file.readlines()
   else:
start()
But i am only focusing on:
def start():
      authentication()
   else:
start()
In the 'startingChoice == "2":' bit!
Thanks!
Specs:
Motherboard: Gigabyte Z97X Gaming 3
CPU: Intel Core I7 4790K
GPU: Gigabyte G1 Gaming GTX 970
RAM: HyperX Fury 16GB
HDD: Seagate ST3000DM001 3TB
SSD: KINGSTON SV300S37A480G 450GB
Cooler: Corsair H100i GTX
Case: NZXT H440 Red
Monitor: DELL U2412M
Keyboard: Gigabyte Force K7
Mouse: Corsair Sabre RGB
https://linustechtips.com/topic/1013455-maximum-numbers-python-file-reading-help/
Just now, badreg said:
If you write to scores.txt as a dictionary, you will be able to load the array, sort it, and output the highest five values. By storing the data as raw text, it is very hard to manipulate it later.
How could you do that?
Specs:
Case: NZXT H440 Red
Readlines will generate a list, so you can iterate each entry in the high score file. From there on, split it by the comma, perform an lstrip and rstrip to remove leading and trailing white spaces on the score entry, then convert the entry into some numeric value instead of leaving it as a string, such as calling int().
From there on you can find a way to sort the data.
Edited by M.Yurizaki
Again, how can you do that in the code. I'm not that advanced.
Specs:
Case: NZXT H440 Red
I don't know Python syntax, so you'll have to figure out the code on your own. However, you should understand that dictionaries are the proper way to store key-value pairs in Python.
Here is a primer on dictionaries:
https://www.pythonforbeginners.com/dictionary/how-to-use-dictionaries-in-python
And an example on how to sort by value:
https://stackoverflow.com/questions/613183/how-do-i-sort-a-dictionary-by-value
Here's a code snippet.
scores = []
for line in text:
  score_entry = line.split(',')
  scores.append(int(score_entry[1]))
I found that int() doesn't care about the white space anyway.
Aren't they the same as arrays and I am using files to be able to store lots of users at a time and can expand without directly editing the file.
Specs:
Case: NZXT H440 Red
scores = []
for line in text:
  score_entry[1] = score_entry[1].lstrip()
  score_entry[1] = score_entry[1].rstrip()
Sorry for being a burden, but how would I put that into my code.
Specs:
Case: NZXT H440 Red
No, arrays are a list of values (i.e. scores = [5, 7, 3, 11]), while dictionaries are pairs of data (i.e. scores = {Alice: 3, Bob: 7, Charlie: 12}).
No, arrays are a list of values (i.e. scores = [5, 7, 3, 11]), while dictionaries are pairs of data (i.e. scores = {Alice: 3, Bob: 7, Charlie: 12}.
I did this in a file so I can future proof the code and add unlimited amounts of users.
Specs:
Case: NZXT H440 Red
I edited my post, but you don't actually need the lstrip and rstrip steps.
Otherwise, you copy and paste it where you want it to run. However, I'd advise actually playing around with the code and figuring out where to best put it on your own.
How can i print the result, so it ends up like:
The top 5 scores are:
	1. Jack with 5.
    2. Oliver with 4.
    3. Emily with 3
    4. Jean with 2
    5. Mike with 1
So does this code pick out the higher scores then as well.
Specs:
Case: NZXT H440 Red
import csv
def printScores(n):
    # Create a dictionary from the text file
    scores = {row[0]: int(row[1]) for row in reader}
  scores = [(k, scores[k]) for k in sorted(scores, key=scores.__getitem__, reverse=True)][:n]
  # Print
  pos = 1
    pos += 1
def start():
    # Print the top 5 scores
    printScores(5)
If you have any questions, feel free to ask.
18 minutes ago, mshaugh said:
import csv
def printScores(n):
  # Print
  pos = 1
    pos += 1
def start():
    printScores(5)
Thanks, just put it in and now trying to learn how each of it works.
Specs:
Case: NZXT H440 Red
40 minutes ago, mshaugh said:
import csv
def printScores(n):
  # Print
  pos = 1
    pos += 1
def start():
    printScores(5)
Sorry to bother you, but two quick questions:
1. Can this be made any simpler?
2. What statement can you add to print out if there are no scores inside the file (I am kinda new to CSV so I don't know that much about it)?
Thanks!
Specs:
Case: NZXT H440 Red
What do you mean by "simpler"?
CSV simply stands for comma-separated values, and the eponymous module just implements classes to read/write data in this format.
What statement can you add to print out if there are no scores inside the file?
All we need for this is a slight modification to the `printScores` function.
def printScores(n):
  # Print
  if len(scores) > 0:
    pos = 1
      pos += 1
  else:
The simplest (and slowest) way to find the maximum score is shown below. If you choose to go this route instead of the preferable route already shown, I will leave it to you to figure out how to modify it to track the highest 5 scores (this is homework, after all). I will also leave it to you to figure out how to determine if the file contains no scores.
  1. Initialize two variables, max_score_name and max_score, to an empty string and the lowest possible score, respectively.
  2. Check if you've reached the end of the file. If not, go to step 3, otherwise go to step 6
  3. Read a (name, score) pair from the file. Set the variables current_name to the name, and current_score to score, after converting it to a number.
  4. If current_score is greater than max_score go to step 5, otherwise go to step 2.
  5. Replace max_score_name with current_name, and max_score with current_score. Go to step 2.
  6. Display the max_score_name and max_score.
I should also warn you that you shouldn't copy and paste anything from this thread into your homework. If your teacher googles "maximum numbers python file" (or any combination thereof), this thread is one of the first results returned.
ENCRYPTION IS NOT A CRIME
Here's another solution, with an example of how to use it.
# itemgetter allows sorted() to sort by entries in a list
from operator import itemgetter
text = ["Alice, 83", "Bob, 29", "Charlie, 20", "Dave, 48", "Eve, 9", "Fred, 10", "George, 58", "Hellen, 69", "Isabelle, 2", "Jordan, 81", "Alice, 100", "Dave, 99"]
def print_high_scores(scores, last_place=5):
    entries = []
    # You can replace this for-iterator with a CSV reader if you want
    for score in scores:
        score = score.split(',')
        score[1] = int(score[1])
        entries.append(score)
    if len(entries) == 0:
      print("No scores available")
    else:
      entries = sorted(entries, key=itemgetter(1), reverse=True)
      place = 0
      print("Top", last_place, "scores")
      for entry in entries:
          if place == last_place:
              break
          print(str.format("{0}. {1}: {2}", place+1, entry[0], entry[1]))
          place +=1
    return
print_high_scores(text, last_place=3)
print()
print_high_scores(text, last_place=10)
print()
print_high_scores(text, last_place=5)
The problem with putting the scores into a dictionary is that it doesn't allow the same name to have multiple scores.
But as usual, I highly advise you look through and see how this code works rather than copy, pasting, testing that it works, and calling it a day if it does.
And because I'm bored, alternatives solutions that don't involve itemgetter
This method does use a dictionary, but instead of using the name as the key, it uses the score as the key and a list of names as the value. This gets around the issue of not allowing the same person to have multiple scores .
This approach is a bare-bones that implements a bubble sort routine if one didn't know anything about Python's built-in sort function:
text = ["Alice, 83", "Bob, 29", "Charlie, 20", "Dave, 48", "Eve, 9", "Fred, 10", "George, 100", "Hellen, 69", "Isabelle, 2", "Jordan, 81", "Alice, 100", "Dave, 99"]
def swap(in_list, first, second):
    temp = in_list[first]
    in_list[first] = in_list[second]
    in_list[second] = temp
    return
def sort_scores(scores_list):
    end = len(scores_list)
    x = 0
    swapped = False
    while x < end:
        swapped = False
        first_num = scores_list[x]
        for y in range(x, end):
            second_num = scores_list[y]
            if second_num > first_num:
                swapped = True
                swap(scores_list, x, y)
        if swapped == False:
            x += 1
    return
def print_scores(scores, last_place=5):
    entries = {}
    score_numbers = []
    for score_entry in scores:
        score_entry = score_entry.split(',')
        score_name = score_entry[0]
        score_number = int(score_entry[1])
        if score_number not in score_numbers:
            score_numbers.append(score_number)
        if score_number not in entries:
            entries[score_number] = []
        entries[score_number].append(score_name)
    if len(score_numbers) == 0:
    else:
        sort_scores(score_numbers)
        place = 0
                break
            place +=1
print_scores(text)
This approach uses Python's built-in sort function
    entries = {}
    score_numbers = []
    else:
        score_numbers = sorted(score_numbers, reverse=True)
        place = 0
                break
            place +=1
print_scores(text)
Also while I can see merit in doing a with file approach in the print function itself, I don't like it because I consider that functionality an interface. While it sort of conflicts with the "You ain't gonna need it" principle, I like the function to accept the actual data its interested in rather than an indirect reference to that data.
2 hours ago, mshaugh said:
def printScores(n):
  # Print
  if len(scores) > 0:
    pos = 1
      pos += 1
  else:
Specs:
Case: NZXT H440 Red
def printScores(n):
  # Print
  if len(scores) > 0:
    pos = 1
      pos += 1
  else:
def printScores(n):
  # Print
  if len(scores) > 0:
    pos = 1
      pos += 1
  else:
Thanks, just going to understand now how the new version works.
Specs:
Case: NZXT H440 Red
