I recently bought a laptop that didn't have a lot of space, so I bought an SSHD for my laptop. I've only had the laptop for about a week and it worked ok. I heard a sound that felt odd, not sure how to describe it, so here. I thought I might have installed it incorrectly, so I went and tried to open the laptop up and reconnect it. Bad idea, because now my laptop won't even register the hard drive and it still makes that noise. What do I do? :(
https://linustechtips.com/topic/1013235-sshd-died-help/
RMA. Bad drive. It happens. If you want data off of it, use something like this https://www.amazon.com/Sabrent-2-5-Inch-Adapter-Optimized-EC-SSHD/dp/B011M8YACM/ref=sr_1_3?ie=UTF8&qid=1545883675&sr=8-3&keywords=2.5+inch+to+usb+3 and try attaching it as external drive and see if it detects. If not you're out of luck. Pretty sure you can RMA the drive.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/1013235-sshd-died-help/#findComment-12121869
