So i got a rx 570 for Christmas and i installed it downloaded the drivers. I stressed it everything went ok after i benchmarked my cpu and gpu and my system just turned of. I think its bcuz of my psu.
Specs:
Intel Pentium g3258
Rx 570 8gb
2x4gb ddr3
Old psu vs 450
Z97 msi pc mate
500gbhdd
240gb ssd
My budget is 50-60
https://linustechtips.com/topic/1012375-my-system-shutdowns-randomly/
a 570 is wayyyy overpowered for such a cpu. what is your monitor resolution? ahhh...a gift...keep that gpu and later upgrade, you will see much improvement.
and OLD PSU? is 450 peak watts? brand? name? stats on side?(pic?)
some psu have overwattage protection, If you unplug and switch the psu off, the hit the power button to empty the capactiors, then plug it back in and switch it back on what does it do?
A good 450W PSU should be fine for that system. See from other thread OP is in Europe. Think either Corsair CX450M or CX550M if in budget would be nice budget choices. I use those for my budget builds.
Later on, maybe look for a used i5 or even i7 Haswell CPU to upgrade, should give a nice lift there too.
My old psu was a corsair vs450
just to say man, you have a z board which is very decent, with a very low cpu, so if you can find a i7 4770 or 4790 for a decent price that is literally the best single cpu for ddr3 ram. and will be up to snuff with even the newer cpus though not the best as it once was.
have you tried turning it back on? does it do anything at all? do you have another computer or PSU you can test with?
tried different outlet/fuse? other things work plugged in there?
5 minutes ago, thx1138 said:
can you smell anything from the comp? open the side panel, see any lights? fan spin? smell the PSU itself, anything?
It doesnt smell and the fan spins.and wgen i turned it on again nothing happend it just turned on like normal. But i have read that the VS series really bad is.
http://www.jonnyguru.com/forums/showthread.php?t=10184
is reviews and thoughts about it and the possible cx 'upgrade'
you can definitely get better...but you can also get the same or worse.
Look at your local places and e-commerce, then take the name and google with 'jonnyguru' most of the time they have the info your looking for in pretty easy to understand forms.
check your temps as well with hwinfo 64, if you havent.
if your psu is really old, the fan could also be dying and thus the psu overheating.
its 7:48am where im at though....so good night, and good luck, oh and rebates are awesome...if they work.
You should get a new psu regardless. That unit is trash.
Ryzen 5 2600 3.9Ghz all cores 1.175V | MSI X470 Gaming Pro | 16GB ADATA Gammix D10 @ 3000C16 | Sapphire RX 5700 XT Pulse | Samsung 970 EVO Plus 250GB & 2x Samsung 860 EVO 500GB | Super Flower Leadex II 650W | Phanteks P350X
Asus VG245HE 24" 1080p 75hz | Logitech X-540 5.1 | Logitech G710+ MX Brown | Logitech G502 Hero | Logitech G440
