Ive got a Meizu M3 Note, and have recently added the SIM from my work phone to it in order to use the masses of mobile data my work provides. My phone can use both SIMs, and gets a solid connection, but when I set it so that my work SIM is used for mobile data, it stops receiving a connection via my personal SIM. any idea why this would be happening?
https://linustechtips.com/topic/1012321-problems-running-dual-sims/
Do both slots support the bands you need?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I've got no idea. I was trying to run 4G on the work SIM. I might try swapping my personal SIM into position 2, and work SIM into position 1, see if that fixes things. I don't see why that would cause a disconnect, but worth a try.
Is most likely a dual SIM standby. It can only use one SIM at a time. If you want to use two SIMs at once you need to look for a dual active SIM phone.
You'd want to figure that out.
You'd also want to look into what @r4tch3t said, as there are different dual SIM set ups. IIRC dual sim dual active is not common.
