On 12/24/2018 at 2:03 PM, filippalfi said:
700D would fit it perfectly, but its waaay out of budget. Something like it, or something Linus and Rod or Bob, not sure, used on one of the Scrapyard wars. Silver and blue build if u can remember, and Luke did Mad Max style PC.
Try the 750D then, it's just as large but is way cheaper. There's an Airflow Edition too (which I would recommend to help keep temps down)
https://linustechtips.com/topic/1012059-case-recommendation/#findComment-12119417
Found the 800D on local market, used, for 100$, so ill grab that.
https://linustechtips.com/topic/1012059-case-recommendation/#findComment-12119630
