Hey all, hope your holidays are going well. I'm having a hell of a time here with my 8700k, if it weren't for eggnog and rum I'd probably have already thrown it out the window. So all I'm trying to do is get a meager 4.7GHz on all cores. I can achieve this by setting the vcore to 1.225, LLC to HIGH (I'm using a Gigabyte Aorus Z370 Gaming 5) with good temps and a max vcore of 1.276v reported in HWMonitor. The issue is, I want to use ADAPTIVE voltage so I'm not running at max voltage all the time, this is where things stop making sense to me. I had my DVID offset to -0.115 and LLC to HIGH earlier and thought that I was stable but started crashing when running benchmarks or playing games. Here's the thing, with that particular offset, my reported vcore is 1.250ish with a max of 1.308. Why am I stable at a lower vcore using manual voltage but not stable using adaptive at this higher vcore? I've tried using TURBO LLC but that's not helping me either. Can anyone explain this to me and possibly help me achieve 4.7GHz w/ adaptive voltage?
MSI Prestige 15
i5 10210u - 8GB DDR4 2666MHz - GTX 1650 Max-Q - 500GB SSD
Hinges still intact!
https://linustechtips.com/topic/1011937-help-with-8700k-oc/
-0.115 is a big drop  and can cause instability while the cpu fluctuates in load.
I personally can't use anything more than -0.025 (note the extra 0) on my z390, i think on my z370 extreme4 the max was -0.07, so ya, -0.115 is alot, if you don't like using the extra voltage, use a lower voltage llc, or just clock the cpu higher.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1011937-help-with-8700k-oc/#findComment-12112271
So this is due to the fluctuations with adaptive then? I don't think I fully understand how DVID works.
MSI Prestige 15
https://linustechtips.com/topic/1011937-help-with-8700k-oc/#findComment-12112292
the offset on my boards at least affects the idle voltage and everything in between, so if the idle voltage is too low or you go from a high usage area (4.7 stable at 1.27-1.3v) then go to a low usage area (i'm guessing here, 3.6 0.95v) then it might not be stable, and since you are using a -0.11 offset i'd say that's likely. So you need to find a less aggressive offset that works all voltages/speeds (you'll have to use a llc that pumps out less voltage at full load)
https://linustechtips.com/topic/1011937-help-with-8700k-oc/#findComment-12112301
Holy crap I think I got it..... So I was missing a crucial step, I needed to ensure IA AC/DC Load Line was set to auto and then in "VR Control" I had to set IA AC and IA DC both to 1. This caused my voltage to go flat at around 1.280v when I set my DVID to +0.000 at 4.7GHz. From here I applied my offset if -.055 and finally set my LLC to HIGH and it looks good so far! I don't remember ever having to set IA AC/DC on other boards and frankly I don't even know what the hell it does, but it works.
MSI Prestige 15
https://linustechtips.com/topic/1011937-help-with-8700k-oc/#findComment-12112334
lol...whatever works, i have no idea what those are, i had problems with fluctuations until a bios update fixed it for me
https://linustechtips.com/topic/1011937-help-with-8700k-oc/#findComment-12112352
I just read into it and apparently they prevent voltages from exceeding your set vcore when using an offset. Thanks for your help!
MSI Prestige 15
https://linustechtips.com/topic/1011937-help-with-8700k-oc/#findComment-12112356
