Hello everyone,
My friend is building is first gaming PC right now, and he told me that the PC isn't booting. I told him to check the front panel connectors and change the slot of his RAM (idk if that even would fix anything), but still no luck.
Any ideas?
Specs:
Ryzen 7 1700x
Asrock B350 Pro4
8 gb RAM (1x8)
Corsair CX550M
MSI GTX 970
and a molex RGB LED strip
Thank you.
EDIT: Well this turned out well... Apparently he just put all the front panel connectors to the wrong connectors
https://linustechtips.com/topic/1011082-pc-not-booting-first-time-building/
Make sure the psu power switch is on, ensure cpu power connector is in firmly, along with the 24pin and same goes for gpu. Also make sure, being a semi modular power supply, that the correct cables are plugged into the correct areas on the psu (they're all labeled). You could try booting without the gpu as well.
I dont think changing RAM slots would help. Another thing to try is reseating the CPU.
