Search In
  • More options...
Find results that contain...
Find results in...
Windows 10 Pro 64bit 1803 HELP!
_Hustler_One_
 Share
Hi all,
I was starting my PC, booted up to windows, and it started initializing update from 1803 to 1809, while I see 1809 has many problems.. I cant stop it from downloading it.. I want to just cut my Internet connection but I'm worried..
What should I do???? please HELP!
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
Nothing really you can do, if it is already downloaded and waiting for reboot to install it cannot be stopped AFAIK.
Many of the issues have been resolved as well.
You can in the settings app under update and security delay all updates for up to 30 days, but once that expires it will immediately install all missing updates.
I need to be convinced more that 1809 is now good to have. I'm still have some worries if my files are deleted by it and the other problems are still potentially remains there..
I just paused it until next 35 days..
My system specs:
My build logs:
deleted files bit is from Known folder redirection that has been fixed awhile ago
so 1809 is good to have now?
My system specs:
My build logs:
No. It is still shit. Since you have the Pro, you can delay Windows 1809 upgrade for a year max.
How to extend the delay period? I thought it's only 35 days max
My system specs:
My build logs:
You have to look into Windows Update Group Policy where there will be an option for deferring upgrade.
 Share
