My i7-9700k refuses to run at high speeds. After a day of messing about and getting it to be fully stable at 5.1ghz, it now just cripples itself all the way down to 1.6-1.8ghz when cinebench is 50% done.
Anyone got any idea why? The thermals are not reaching above 90-94c.
Using a 750watt gold power supply that was able to handle it just fine before.
Edit: I have also tried to run it at stock speeds, exact same thing. And prime95 just refuses to let it run higher then 4.6.
https://linustechtips.com/topic/1010413-cpu-refusing-to-run-at-high-speed/
90-94 degrees centigrade? Yeah, that's just fine, especially when TjMax is 100 degrees. VRM temps might have something to do with it also, what board do you have? And as for Prime95, that uses AVX which probably has a multi of around 46.
z390-a
I know it thermal throttles to 4.6ghz when using prime95 full on cpu.
I am just not sure, this is not thermal throttling. It was working fine before. I dunno if it's my power supply, but then  I gotta wonder why it's acting up now
2 minutes ago, MysticDragon said:
z390-a
the board might be blasting too much voltage into the chip, the early z390 bios were atrocious. Also, vrm temps might be triple digits if ur cpu is 94C
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Just now, jordancregan193 said:
That isn't thermal throttling that's bringing the speed down to 4.6GHz. That's AVX, which is a much more demanding instruction set that is rarely stable at the same frequency compared to other instructions. Check your VRM temps.
It is. 1 core reaches 100c and another peaks at 100c when using prime 95
The motherboard is like 1 week old, so the bios should be up to date. I also have it set at 1.36volts, something that worked fine before
Age of the motherboard has nothing to do with what BIOS is loaded on it. That could have been one of the first just sitting on a shelf somewhere.
2 minutes ago, jordancregan193 said:
So you are hitting TjMAX. Well that's your problem then. Fix your cooling solution at stock, then wonder why it isn't working when overclocked.
No i'm not. I'm hitting 90-94 c on non avx, and same goes for avx so long as I am not trying out that stupid prime95 test that legit is not even healthy for your cpu cuz of the stress it unloads onto it
You literally just said "It is. 1 core reaches 100c and another peaks at 100c when using prime 95". That's Thermal Junction Max, which is not something you should be running your CPU at. Have you figured out what your VRM temps are?
When I am running the most intense test out there on the webs, it does yeah. Like 95% of all other cpus running on air. Don't exactly know how to see it
A computer isn't stable until it's always stable. There's no such thing as "it's stable for this". I mean it could be, until it's not. Your PSU won't affect clockspeeds, if it was faulty and not providing the right amount and type of power it might bring down the system, however. The three main things are a power limit (which wouldn't bring your clocks down that far), a cpu core temp limit (which at 90-94 degrees it shouldn't be an issue) and a vrm temp limit (which you said was 50-75 degrees, so that also isn't a problem).
Then I honestly don't know. It was fine before, now it's not all of a sudden. :/
I think it's my psu not being able to provide enough.
I just recalled testing out the ocing without all my 5 hard drives and 1 disk reader being installed, with is like 125 watts on it's own it no longer can take.
Still find it strange given my gpu (rtx 2080 ti) prob draws no where near enough when not loaded for it to matter, but hopefully buying a 1000watt+ psu will fix it
I'll test the OC tomorrow without my hard drives installed
What CPU cooler do you have? CPUs are supposed to get hot. It's your job to cool it. If it's hitting 100c then it has plenty of power from the PSU.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
2 hours ago, MysticDragon said:
ill say this once before you fry your comp, you are hitting tjmax, 94 can spike to 100 anytime. temps are 100% the problem, and running 5.1 1.36v without adaquate cooling is just insane.
I'm using the dark rock pro 4
Honestly de-lidding and liquid metal is the only way I can see myself lowering temps now. The dark rock pro 4 is only 4 degrees hotter then the better water coolers out there, something I am not willing to touch cuz I know i'll break it
I'm clearly already breaking this cpu ?
