lol
Why would you bother trolling us watercooling an i5 that can't overclock?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12099054
6 minutes ago, hackgod said:
Should i go with hyper evo x12
yes
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12099083
2 hours ago, My2t1c said:
lul didnt notice that :)
le researche
btw im actualy austrian
Then you already know your real French grammer and stuff a bit. Not like le Quebecois stuff they tried to teach me in school
".........but i am le tired, ... WELL then take a NAP, AND ZEN FIRE ZE MISSLES......"
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12099139
Stock cooler should be fine unless you think it's too noisy.
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12106536
4 minutes ago, hackgod said:
I am in India
Are you using Amazon or some other stores? If you link them, I can check if there are better options than 212 in same price range.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110118
1 minute ago, hackgod said:
I will use Amazon
My pc build parts ☝
https://www.amazon.in/Deepcool-GAMMAXX-400-Universal-Cooler/dp/B007JEMXYQ/ref=sr_1_8?s=computers&ie=UTF8&qid=1545566825&sr=1-8&keywords=Cpu+cooler this is better option than 212, bit cheaper too. There's Frostwin from Deepcool if you would be getting OC capable CPU.
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110144
Cooler Master Hyper 212 Led Turbo Red Cover Xtraflo 120Mm Pwm Fan with Quick-Snap Fan Bracket Design (Rr-212Tr-16Pr-R1) https://www.amazon.in/dp/B06VWX2QLT/ref=cm_sw_r_cp_apa_i_813hCbC5GKR01
Check it out
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110157
Check it out
It's still overkill, but your choice.
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110277
8 minutes ago, hackgod said:
Will it fit in spec 1
Actually no. Case can fit 154mm coolers. So Gammaxx 400 does fit barely.
https://www.amazon.in/Deepcool-Gammaxx-300-Universal-Cooler/dp/B007JEMX4Q/ref=sr_1_95?s=computers&ie=UTF8&qid=1545579788&sr=1-95&keywords=Cpu+cooler
This one does fit.
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110445
33 minutes ago, LoGiCalDrm said:
What about Corsair hydro h80i GT
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110529
1 hour ago, LoGiCalDrm said:
The clearance listed for Corsair Spec cases are conservative and don't account for the side panel bump.
Here are some examples with the Hyper 212 Evo:
Spec-01: https://pcpartpicker.com/builds/by_part/hmtCmG#e=644
Spec-02: https://pcpartpicker.com/builds/by_part/hmtCmG#e=455
Spec-04: https://www.amazon.com/CORSAIR-Carbide-SPEC-04-Mid-Tower-Gaming/dp/B06XTPNCMM
Every cooler mentioned so far is overkill. Why not stick with the stock cooler?
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110582
You mean that hyper 212 Evo will fit in spec 1
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110594
Yes. The links I provided show systems with the 212 Evo being used on the Spec-01. That being said, the Gammaxx 400 mentioned is better and probably cheaper.
https://linustechtips.com/topic/1010364-cpu-cooling/#findComment-12110600
