monitor
Vigneshqw
is 60 fps gameplay
better in 120hz monitor
or it is useful only for 120 fps
tvs only work in 30 fps
but why refresh rate is 120 hz
can you phrase this a little better? Whats is your GPU and what games do you want to play? For example if you have a GTX 1070 and up a 144hz monitor is usually worth depending on what you like to play
I agree w/ ^. Can you word this a little better?
But from what I get out of this "question" is that you're asking if 60fps looks better on 120hz, right?
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
i have 1050ti i get about 60 fps
i play gta5
will buying 120 hz moniroe increase performance @60 fps
or its for gamers who get 120 fps from gpu
i play gta5
Refresh rate doesn't dynamically adjust to match frame rate. In other words, although you are only getting 60 'unique frames' every second, the monitor is essentially duplicating the frames to fit into its refresh rate. The monitor is also giving you twice as much 'visual feedback' every second in relation to your controller movements so things will seem much more fluid than at 60Hz. The benefit gained by additional frame rate (ideally 120fps) would be an additional reduction in motion blur.
Rig: 5950X | ROG VIII Formula | 6900XT
Laptop: 5900HX | 6800M | 16GB
