guys in gonna build a new nice pc in 20 days so suggest me a ram to get.
i5 4670k,gpu gigabyte gtx770 2gb oc edition,mother:msi z87-g43 gaming,chassis:corsair 230t orange or grey,hhd:wd blue 1tb,ssd:120gb samsung evo 840,ram:...........tell me,psu:coolermaster 700w thunder.
tell me your general opinion about this build.what i do wrong help me.
finally im between corasir vengeance blue 2x4 or corsair vengeance PRO 2x4 (1600mhz both)????
i think they are pretty same
https://linustechtips.com/topic/100834-help-me/
The pro is not worth it, go for the blue low profile one.
CPU: 3570k @ 4.8Ghz MB: Gigabyte Z77-UD5H GPU: GTX 1060 PSU: BeQuiet PP 630W OS: Mac OSX & W10 Ram: Corsair Vengeance Low Profile 16gb 1600mhz Storage: 1x Samsung 860 EVO 1TB; 1x Samsung 850 evo 250GB  Case: Fractal Design Define R4 Audio: Fiio E10 & Sennheiser HD558 Display: Eizo FS2333
https://linustechtips.com/topic/100834-help-me/#findComment-1348474
why low profile?i like the sexy one with the teeth :)
because later on you have the choice to buy a big cooler for your cpu
https://linustechtips.com/topic/100834-help-me/#findComment-1348483
770 isn't that good of a card if you want to future proof. Since the 4GB is useless with it. So you might want to wait for Maxwell.
770 is a great card for the price...
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/100834-help-me/#findComment-1348486
i already have a cooler.pretty big
cooler master 212 evo
it will be a problem about these sexy vengeance?so i should take the low profile>?
http://www.tomshardware.co.uk/answers/id-1681949/hyper-212-evo-ram-clearance.html
https://linustechtips.com/topic/100834-help-me/#findComment-1348508
770 isnt good wtf?
maxwell is what?idk
Maxwell is the new Architecture for Nvidia, the 770 and 760 are based on the same architecture. So Maxwell will be completely different, less power consumption and more performance etc.
The reason I'm saying that the 770 isn't worth it is because the 4GB version cannot use all of the VRAM. So, when you get into games that use more than 2 gigabytes your game will slow.
This is my thread about the whole bus issue for the 770/760 4GB. Read it so you know to make an educated decision when you get a new card: http://linustechtips.com/main/topic/76184-why-not-to-get-the-760770-4gb/
There are 10 types of people in this world, those who understand binary, and those who don't.
https://linustechtips.com/topic/100834-help-me/#findComment-1348544
but i said about the 2gb version.the same things about 2 gb?
https://linustechtips.com/topic/100834-help-me/#findComment-1348570
It's not totally useless, the card may only be able to actually use 2GB but because it has 4 it won't crash due to a lack of VRAM when the usage exceeds 2GB, a 2GB card will crash. So while a 4GB card is overkill it's not pointless.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/100834-help-me/#findComment-1348575
wtf are u talking about man?
i will not be able to play bf4 and crysis on gtx 770?Are u fucking kidding me?
https://linustechtips.com/topic/100834-help-me/#findComment-1348580
770 isnt good wtf?
maxwell is what?idk
maxwell is the next generation of nvidia cards( 900 series if I remember correctly. the 800 series cards are the oem 700 series)
the 770 is a good card if you want those nvidia features(shadowplay, g sync) if not, I'd suggest the 280x or 290 with an aftermarket cooler
and getting the 4gb version of the 770 won't help you with anything if you're playing only on 1080p
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/100834-help-me/#findComment-1348589
What are you talking about? of course you can run the game. It's a known fact that when a game exceeds the available VRAM it either stutters badly or crashes, hence why having a GPU with more VRAM than it can fully utilize isn't entirely pointless, in this case with the 770 4GB is overkill but a 3GB card isn't available for a middle ground. You also didn't mention what resolution your monitor is or will be, 2GB is enough for 1080p for now but it's not really enough for 1440p or above.
https://linustechtips.com/topic/100834-help-me/#findComment-1348714
The build is pretty good imo. I would change the power supply to a XFX Core 550w as 700w for a single gpu is too overkill unless if you plan in SLIing in the future which might be borderline. For the ram, if you are using it for gaming, I would just get the cheapest 8GB CL9 1600mhz ram as it doesn't really matter.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/100834-help-me/#findComment-1350053
It can get in the way of coolers.
I'd suggest getting a more reputable psu.
Also, don't make duplicate posts: http://linustechtips.com/main/topic/100832-which-ram-is-good-for-me/
https://linustechtips.com/topic/100834-help-me/#findComment-1350660
really ty
https://linustechtips.com/topic/100834-help-me/#findComment-1354512
but gigabyte says that the card gtx 770 needs at least a 600 watt power suplly.maybe this is for scary people?
if not suggest me a good power suplly with less watts exept the xfx
https://linustechtips.com/topic/100834-help-me/#findComment-1354522
They recommend 600w because they are including cheap power supplies in this that usually won't provide the wattage that they say. Here is an cpu overclocked system and it used around 300w which leaves you with room for overclocking your gpu.http://www.guru3d.com/articles_pages/geforce_gtx_770_review,5.html
The XFX power supply is made by Seasonic which makes great quality power supplies. If you want a psu that is not XFX, the SeaSonic G Series SSR-550RM/SeaSonic S12G S12G-550 550W (depending on budget).
https://linustechtips.com/topic/100834-help-me/#findComment-1354956
