Right click the graph > Change graph to > Logical processors
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1007547-cpu-cores-not-showing/#findComment-12073831
9 minutes ago, Baske996 said:
Does anyone know why it says that cpu has 2 cores but its ment to be a quad core?!
Hopefully this block diagram of the CPU you have makes things clear:
Basically AMD markets your processor as being "Quad core" because they count each "Integer Core" as... well... a core. However as far as the OS is concerned, the entire module is a core because each of those Integer Cores share a single input port on the top of the diagram. The OS can't directly put work on the integer cores separately. It can only schedule two threads on the module and hope for the best.
https://linustechtips.com/topic/1007547-cpu-cores-not-showing/#findComment-12073848
Just now, Baske996 said:
No, this cpu came with the prebuild system i bought quite some time ago, but now i noticed that!! Thanks for info tho.
ah good, some people end up doing some questionable pruschasing decisions at times.
https://linustechtips.com/topic/1007547-cpu-cores-not-showing/#findComment-12073849
