Moody X58 System
Go to solution Solved by wojtepanik,
did you pull out the cmos battery?
Alright, so about a month ago I had my system (ASUS P6T WS Pro on latest BIOS, Xeon X5650, 12GB Kingston DDR3) running stable at 4GHz (200x20).
I watched an X58 overclocking guide and decided "why not. let's go higher". So I tried to OC higher, I'm not sure if I tried to do multiplier x22 or up the BCLK a bit more.
The point is, that did not work, no matter the voltages, timings or anything. I never went above anything unsafe (never above 1.3v, I believe it was).
So I decided "whatever, the old OC is fine". Except that I typed in the BCLK, multiplier and voltages and... no POST. "okay, maybe it's too high". 180 BCLK and nothing.
So now I have to stick to a 160 BCLK and an x20 multiplier because I can't lock in the x22 stably. The highest I can go on the BCLK now is 164, and going that high introduces issues with my USB audio interface. Anything higher will not post and turn on the DIAG_RAM light.
I don't know what to do! My old clocks don't work anymore. I tried reseating the RAM and only 8GB were detected (so I was missing a channel, it's 6x2GB). I reseated it again and at least I got my third channel back, but no dice on higher clocks.
Does anybody know what might be happening? Did I f*ck the memory controller or the memory itself? Shall I pull out the PC again and try reseating everything once more?
Thanks.
https://linustechtips.com/topic/1007287-moody-x58-system/
Have you tried to reset the bios settings? And maybe you could try a bit higher voltage, for example 1.325V
Intel Core i9-9980XE 18c/36t, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Palit RTX 5070, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, Meshify 2
PC 2: AMD Ryzen 7 3700X 8c/16t, MSI X470 Carbon, 32GB DDR4 2666MHz, Asus GTX 1080 Strix, 512GB Samsung PM981, 1TB Crucial MX500, Fractal Define R4
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 48GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 3: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Phone: Samsung Galaxy S23 256GB Watch: Samsung Galaxy Watch7 44mm LTE
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
Z77: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 32GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
https://linustechtips.com/topic/1007287-moody-x58-system/#findComment-12071178
Okay everybody, it's been a few days (a week) and I've tried all your suggestions.
I tried going back to defaults and back up from there several times, I've opened it up and reseated everything, even pulled out the battery. But no dice.
At this point there's not much I can do except live with the CPU at 3.2 GHz (which is a bummer because 4 GHz was working fine), contact ASUS support or start saving up for a new platform (which is gonna be hella expensive for the same level of performance) instead of a graphics card upgrade (I'm currently on a 750 1GB).
Thanks, y'all. I'll let you know how it goes.
https://linustechtips.com/topic/1007287-moody-x58-system/#findComment-12094088
A typical problem when you oc on X58 with BLCK. Is that as you increase core clock, you also increase memory and UCLK clock. I have seen severel oc attempts being unstable because memory and/or UCLK clock is not ajusted accordingly as well.
So basic is that you shut not run memory much above the rated spec.
For UCLK clock as the clock goes to 4000 MHz it typically becomes rather unstable and causing BSOD. You shut try keep UCLK around 3600 MHz +/- 100 MHz and at voltage around 1.35 volts ajusted in QPI/DRAM core voltage.
CPU core voltage can safely be taken to 1.4 volts, above that you go beyond what intel reccoments as maximum voltage. The cpu is even rated to operate between 0.750V-1.350V, but maximum volts is 1.4 volts for long term operation. So you have some headroom from 1.3 volts, given that your cooling can handle the higher voltage off cause.
This is my OC settings for 4.42 GHz and note my CPU is a I7 980X, but the volts and settings you shall ajust is the same as i have done in image. But you still need to find what voltages your CPU is stable at. You might need higher or even better lower voltage.
https://imgur.com/a/zOKH0u4
https://linustechtips.com/topic/1007287-moody-x58-system/#findComment-12095286
Running my last x5680 I cooked it at 4.2ghz and started getting every kind of bsod fault. It wouldn't run at any speed without eventually BSODing. Replaced the CPU and kept it at 4Ghz with no problems.
Pick up another $20 CPU and see if it doesn't work again. For a daily driver more than 4Ghz is unnecessary.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/1007287-moody-x58-system/#findComment-12095487
2 hours ago, bimmerman said:
What voltages and multipliers were you running when it was working fine?
What did you try when it stopped working fine?
What/how old/how functional is your PSU?
I was running 200x20 at around 1.22v or so. I've never been able to get x22 really working stably on this board and CPU ever.
I think I tried raising the multiplier to 22 and tried to bump the CPU core voltage along with it. I think I also tried a 210 BCLK, but I don't remember if it was unstable or if it just refused to boot.
My PSU is an Antec CP-850, so the whole system is inside an Antec P183. It's never failed me in the least.
The whole thing was working fine when I got it from a family friend who was moving. Due to the age of the parts and all that ( I got it with a GTX 285 inside), the system must be 9 or 10 years old. I got myself the CPU on AliExpress for about 20€, put it in and freaked out for a few months until I figured out that all I needed to do was update the BIOS. I put in the old owner's i7 950 (which I still have, I might give that a try), updated the BIOS and it ran perfectly. Over the course of a couple of weeks I bumped up the overclocks (mainly BCLK) from 160, to 180, to 190, until finally settling on 200x20. A voltage of around 1.21 or 1.22 served me fine for months.
Yeah, I ran that OC for months with no issues. RAM speed was around what it normally runs at (everything on default leaves the RAM speed at 1333), so that wasn't the problem. I usually have the UCLK around 3, 3.2 GHz, but I'll try raising it to around 3.6.
Still, it's rather strange that all this would occur right after a higher failed OC. I might actually have (partly) fried the CPU. I will try the old i7 950, but still...
https://linustechtips.com/topic/1007287-moody-x58-system/#findComment-12095799
Alright, I've put the i7 950 and it's done... Pretty much nothing.
The board still refuses to boot with BCLK higher than 160. There's a small improvement, in that now I have a max multiplier of 24, but if I decided to stick with this I'd also be losing 2 cores (and the 4 threads that go with them).
I'm going to run Cinebench to see if it's stable, at least for a moment.
Alright, the multiplier seems to be unwavering. I'm going to play a few games and such and see how it goes, but it's still a bummer that the board (or RAM) is misbehaving like this.
Edited by ndfr623
https://linustechtips.com/topic/1007287-moody-x58-system/#findComment-12095985
