Might be in the wrong section but I can't seem to connect an ethernet cable to my gaming pc. My motherboard is the Msi b450i gaming plus ac. The cable is brand new and it works on my laptop but can't seem to get it working on my desktop for some reason. Ethernet does not show up in any of my settings on the computer and seem to be missing, I've tried reinstalling the drivers and all of that.
Edit: The error I get is: the realtek network controller was not found if deep sleep
https://linustechtips.com/topic/1006579-ethernet-help/
Were you previously able to connect to ethernet?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1006579-ethernet-help/#findComment-12064293
Just now, Skyrux said:
No, I've been using the inbuilt Wifi from the motherboard since I build my pc which was about a month ago.
What did MSI customer support say?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1006579-ethernet-help/#findComment-12064303
I haven't contacted them yet, I'll send them a message.
I find that errors like these seem well documented, so they may have something for you.
Then again, it's MSI, so maybe not.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1006579-ethernet-help/#findComment-12064324
Make sure the ethernet card is enabled in BIOS and then make sure you have drivers for it installed.
The card is plain boring Realtek® 8111H which should have drivers built into Windows, but MSI still publishes them on your board's drivers page... here's direct link : http://download.msi.com/dvr_exe/realtek_pcielan_w10.zip (assuming you want for Windows 10 64bit)
https://linustechtips.com/topic/1006579-ethernet-help/#findComment-12064352
That's the exact one I tried to download earlier. No, it did not work if you read my post.
https://linustechtips.com/topic/1006579-ethernet-help/#findComment-12065222
I ended up buying an external adapter for the ethernet port and it works great. I only get half the speed that my laptop gets from the cable but I can manage. 100mb download isn't too shabby.
https://linustechtips.com/topic/1006579-ethernet-help/#findComment-12065228
